[AG-TECH] Re: [AG-L] Lastest kernels (Fedora) causing issues with the AG Software
Christoph Willing
c.willing at uq.edu.au
Mon Jun 23 18:27:20 CDT 2008
On 23/06/2008, at 11:58 AM, Jason Bell wrote:
> Colleagues
> This is just a quick email to warm about issues in regards to updating
> to the latest kernels in Fedora.
> It has been found that using kernels 2.6.25.6-27.fc8 and
> 2.6.25.4-10.fc8
> (Fedora 8) has caused issues in regards to "multiple instances of vic
> (producer and service) "locking up". Basically, only one of the
> streams
> will transmit, whilst the others will lock up.
This isn't just a Fedora thing, I just had the same problem with
another distro upgraded to 2.6.25.8 (although no vic lock ups in this
case). Rather, its a kernel version (2.6.25) issue - in particular
its interaction with python.
For those in a hurry, here's short fix until something more elegant
is devised:
1. edit your ~/.AccessGrid/local_services/VideoService/
VideoService.py (or VideoProducerService/VideoProducerService.py) to
include a new import:
from random import getrandbits
2. then search for "os.getpid()" and replace it with "getrandbits(16)"
3. now restart your VenueClient
For those interested in the background to the problem, each time
VideoService.py is run (i.e. for each video device) an individual
temporary startup file is created containing various startup
parameters including the video device name (/dev/video0 etc.). Each
of these startup files should have a unique name, normally
constructed using the process id of the current (VideoService.py)
process using python's os.getpid() function. Previously this returned
a new pid for each service, but for some reason it now (with kernel
2.6.25) returns the process id of the VenueClient itself. This means
that each of the startup files now has the same name (in fact each
new one overwites the previous one) resulting in all vics being
started with the same startup file. Each vic then tries to open the
single video device named in that startup file. Only the first vic to
run succeeds in grabbing the video device, the others trying to grab
it just cause problems.
Replacing os.getpid() with getrandbits() ensures that each of the vic
startup files has a unique name so that all vics can run as configured.
chris
> An interesting side effect is that you cannot manually "kill" the
> locked
> up "vic" process. Though xkill seems to work.
> Additionally, if you add each stream manually (using configure node
> service), rather than loading from a configuration, this appears to
> work
> fine.
> Will keep you posted when through testing has been conducted and any
> possible resolutions found.
> Therefore, for now, I recommend not updating your kernel and/or
> nvidia /
> xorg drivers.
> We are also investigating whether there are any issues with out
> "Linux"
> variants, but it appears that most other Linux distributions still
> only
> run 2.6.24.xxx kernel, rather than 2.6.25.xxx, which appears to be the
> problematic version.
> Thanks for your time,
> Jason.
> Jason Bell, B.I.T. (Honours)
> Research Systems Support Officer
> Information Technology Division
> Central Queensland University
> Australian Research Collaboration Service
> http://www.arcs.org.au/
> E-mail : j.bell at cqu.edu.au
> jason.bell at arcs.org.au
> Work : +61 7 4930 9229
> Mobile : 0409 630897
> Postal : Building 19
> Bruce Highway
> Rockhampton, Queensland, Australia, 4702
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
> accessgrid-l mailing list
> accessgrid-l at lists.aarnet.edu.au
> http://lists.aarnet.edu.au/mailman/listinfo/accessgrid-l
Christoph Willing +617 3365 8350
QCIF Access Grid Manager
University of Queensland
