[AG-TECH] setting default codec for RAT under Linux (FC8) to other than L16-16K-Mono
Jason Bell
j.bell at cqu.edu.au
Sun Jun 15 17:50:46 CDT 2008
G'day Andrew, Doug and all
This post bring up an interesting issue...
There are times when you may wish to select a different audio codec,
therefore, is it at all possible to modify the "Audio Service" such that
you can make the codec a configurable option??? This can be considered
similar to the Video Codec setting you have in the "Video Services".
Now I understand that in regards to the Audio codec, there are a huge
list of codec's you can select, but maybe it would be useful to have the
popular ones listed.
Just a thought,
Jason.
-----Original Message-----
From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
Sent: Friday, 13 June 2008 11:06 AM
To: Andrew Leahy
Cc: ag-tech
Subject: Re: [AG-TECH] setting default codec for RAT under Linux (FC8)
Hi Andrew,
> After changing the codec & transmission type in RAT how do I make it
stick
> after restarts of RAT?
> OS: Linux Fedora Core 8, AG 3.1 (build 1)
> RAT: rat-4.4.00-0.1.20071214svn.fc8
> We've been experimenting with G726-40-16K-Mono (80kbps) vs the default
> L16-16K-Mono (256kbps).
> I can see where I could kludge something by replacing the string
> "L16-16K-Mono" in
> ~/.AccessGrid3/local_services/AudioService/AudioService.py
> but simply replacing it with "G726-40-16K-Mono" doesn't work.
You could try commenting out the options.append( "-f" ) and
options.append( "L16-16K-Mono" ) lines in AudioService.py
, so that RAT will then make the setting stick by storing it in
~/.RATdefaults.
Doug
