[AG-TECH] Digital DVR
    Antonio Bandeira
    bandeira at fe.up.pt
    Thu Feb 21 10:33:29 CST 2008
Jeff,
Dont know if this is what you are actually seeking for something like the
RGB DGy: http://www.rgb.com/en/Products/ViewProduct.asp?product=DGy
KEY FEATURES:
Computer / radar / sonar / HD / FLIR /
x-ray / audio
Up to 1600 x 1200 resolution
Multicast streaming
Interframe compression
Event marking
Random access
Simultaneous record / playback capability
External time codesynchronization
Variable speed playback
Frame jog / shuttle
Multi-unit synchronization
Compact 1RU size
António Bandeira
FEUP :: SICC ~ uTICM
+351 225 574 199 (ext.3535)
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Ben Green
Sent: quinta-feira, 21 de Fevereiro de 2008 15:46
To: Jeffrey Miller; ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] Digital DVR
Hi Jeffrey,
I'd recommend you storing the AG meeting audio and video data locally using
AGVCR and then converting this data to your desired format.
Unfortunately, I don't know what convertion software is available!
Presumably you're planning on 'playing' the meeting from a PC (either live
or recorded), converting the VGA signal with a scan convertor, and capturing
the AV signal with a DVR?
So you'd simply capture the entire VGA output, i.e. Desktop 1, as opposed to
a nice AVI file that only shows the video clips.
I suppose you could capture with AGVCR on the node PC, transfer this data
onto another PC with AGVCR installed, play it back there, and loopback the
video into a capture card (similarly with audio) and save it in your desired
format.
Alternatively, I believe some DVRs have a built in DVD writer, so it
wouldn't matter about the on screen menus. You can of course output the DVR
to a PC's AV capture card - but you're going from PC to DVR back to PC
again!!
That's just my random thoughts anyway!
Ben.
Ben Green
Access Grid Support Centre
Research Computing Services
University of Manchester
Room G49-H
Kilburn Building
Oxford Road
Manchester
M13 9PL
tel - 0161 306 6621
email - ben.green at manchester.ac.uk
web - www.agsc.ja.net <http://www.agsc.ja.net/>
  _____
Of Jeffrey Miller
Sent: 21 February 2008 15:09
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Digital DVR
Looking for a commercial grade DVR that will record my AG sessions. Want to
record to the hard drive via .avi or .wmv then be able to transfer to DVD.
All the consumer versions like Tivo are all full of recording off-air and
full of TV Guide menus that I dont want or need.
Any suggestions?
Jeff
Jeffrey L. Miller
Office of the Chief Information Officer
Office of Information Technologies
University of Notre Dame
G016 ITC Building
Notre Dame, IN 46556
Office; 574-631-6850
Cell 574-261-1895
jmille22 at nd.edu
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080221/97e5744f/attachment.htm>
