[AG-TECH] Logging level on the venueserver
Jon Johansson
jon.johansson at ualberta.ca
Wed Feb 13 14:45:00 CST 2008
Hi Tom,
Thanks for the info.
I backed up the log file and restarted the venueserver. The last
300 lines from the log file backup are below.
It's all very repetitive. I can zip the whole file (10 MB) and
make it available for download if you think that will help.
Jon.
~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
~~ * Office: G.S.B. 323C ~~
~~ Programmer/Analyst http://sciviz.aict.ualberta.ca ~~
~~ Research Computing Support ~~
~~ Room 352, General Services Building ~~
~~ Academic Information and Communication Technologies (AICT) ~~
~~ University of Alberta ~~
~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
! "This communication is intended for the use of the recipient to !
! which it is addressed, and may contain confidential, personal, !
! and/or privileged information. Please contact us immediately !
! if you are not the intended recipient of this communication. !
! If you are not the intended recipient of this communication, !
! do not copy, distribute, or take action on it. Any !
! communication received in error, or subsequent reply, should !
! be deleted or destroyed." !
-------------------------- Logfile ------------------------
jonj at venues:~$ tail -n 300 /var/log/venueserver.log_2008_02_11
02/09/08 10:29:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
IsIdentificationRequired returning <type 'int'> 0
02/09/08 10:29:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 10:29:39 2008
02/09/08 10:34:38 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 10:34:38 2008
02/09/08 10:34:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 10:34:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 10:34:39 2008
02/09/08 10:39:38 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 10:39:38 2008
02/09/08 10:39:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 10:39:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 10:39:39 2008
02/09/08 10:44:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 10:44:39 2008
02/09/08 10:44:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 10:44:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 10:44:39 2008
02/09/08 10:49:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 10:49:39 2008
02/09/08 10:49:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 10:49:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 10:49:39 2008
02/09/08 10:54:38 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 10:54:38 2008
02/09/08 10:54:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 10:54:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 10:54:39 2008
02/09/08 10:59:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 10:59:39 2008
02/09/08 10:59:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 10:59:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 10:59:39 2008
02/09/08 11:04:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:04:39 2008
02/09/08 11:04:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:04:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:04:39 2008
02/09/08 11:09:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:09:39 2008
02/09/08 11:09:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:09:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:09:39 2008
02/09/08 11:14:38 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:14:38 2008
02/09/08 11:14:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:14:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:14:39 2008
02/09/08 11:19:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:19:39 2008
02/09/08 11:19:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:19:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:19:39 2008
02/09/08 11:24:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:24:39 2008
02/09/08 11:24:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:24:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:24:39 2008
02/09/08 11:29:38 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:29:38 2008
02/09/08 11:29:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:29:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:29:39 2008
02/09/08 11:34:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:34:39 2008
02/09/08 11:34:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:34:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:34:39 2008
02/09/08 11:39:38 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:39:38 2008
02/09/08 11:39:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:39:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:39:39 2008
02/09/08 11:44:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:44:39 2008
02/09/08 11:44:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:44:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:44:39 2008
02/09/08 11:49:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:49:39 2008
02/09/08 11:49:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:49:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:49:39 2008
02/09/08 11:54:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:54:39 2008
02/09/08 11:54:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:54:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:54:39 2008
02/09/08 11:59:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 11:59:39 2008
02/09/08 11:59:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 11:59:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 11:59:39 2008
02/09/08 12:04:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 12:04:39 2008
02/09/08 12:04:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 12:04:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 12:04:39 2008
02/09/08 12:09:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 12:09:39 2008
02/09/08 12:09:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/09/08 12:09:39 -1250219120 VenueServer VenueServer.py:861 INFO
Checkpointing completed at: Sat Feb 9 12:09:39 2008
02/09/08 12:14:39 -1250219120 VenueServer VenueServer.py:829 INFO
Checkpoint starting at: Sat Feb 9 12:14:39 2008
02/09/08 12:14:39 -1250219120 Security AuthorizationManager.py:307 DEBUG
02/11/08 15:59:59 -1209927472 Toolkit Config.py:609 DEBUG System
hostname of venues.srv.ualberta.ca is valid
-------------------------- /Logfile -----------------------
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Thomas D. Uram
Sent: Tuesday, February 12, 2008 7:05 AM
To: Jon Johansson
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Logging level on the venueserver
Hi Jon:
The following options to VenueServer.py affect logging:
-l LOGFILE, --logfile=LOGFILE
Specify a log file to output logging to.
--numlogfiles=NUMLOGFILES
Specify the number of log files to retain
--logfilesize=LOGFILESIZE
Specify the size of log files to retain
Is there an exception in the logfile, or in the shell output, when the
server freezes? We'd certainly like to fix the problem.
Tom
On 2/11/08 5:31 PM, Jon Johansson wrote:
> Hi,
> I'm running an AG 3.1 venueserver on Kubuntu. When the size
> of the venueserver log hits 10 MB the server freezes.
> Is there a command line switch to control the amount of logging?
> I'm running as a non-root user so just setting the log file
> to /dev/null won't work.
> Thanks,
> Jon.
