[AG-TECH] Logging level on the venueserver
Thomas D. Uram
turam at mcs.anl.gov
Tue Feb 12 08:05:15 CST 2008
Hi Jon:
The following options to VenueServer.py affect logging:
-l LOGFILE, --logfile=LOGFILE
Specify a log file to output logging to.
--numlogfiles=NUMLOGFILES
Specify the number of log files to retain
--logfilesize=LOGFILESIZE
Specify the size of log files to retain
Is there an exception in the logfile, or in the shell output, when the
server freezes? We'd certainly like to fix the problem.
Tom
On 2/11/08 5:31 PM, Jon Johansson wrote:
> Hi,
> I'm running an AG 3.1 venueserver on Kubuntu. When the size
> of the venueserver log hits 10 MB the server freezes.
> Is there a command line switch to control the amount of logging?
> I'm running as a non-root user so just setting the log file
> to /dev/null won't work.
> Thanks,
> Jon.
> ~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
> ~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
> ~~ * Office: G.S.B. 323C ~~
> ~~ Programmer/Analyst http://sciviz.aict.ualberta.ca ~~
> ~~ Research Computing Support ~~
> ~~ Room 352, General Services Building ~~
> ~~ Academic Information and Communication Technologies (AICT) ~~
> ~~ University of Alberta ~~
> ~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
> ! "This communication is intended for the use of the recipient to !
> ! which it is addressed, and may contain confidential, personal, !
> ! and/or privileged information. Please contact us immediately !
> ! if you are not the intended recipient of this communication. !
> ! If you are not the intended recipient of this communication, !
> ! do not copy, distribute, or take action on it. Any !
> ! communication received in error, or subsequent reply, should !
> ! be deleted or destroyed." !
