[AG-TECH] AG3.1 vic crashes
Thomas D. Uram
turam at mcs.anl.gov
Thu Feb 7 17:13:08 CST 2008
So far I'm not able to reproduce the problem. I don't have an identical
camera. If you're interested, I can work with you off-list to debug the
problem.
Is anyone else seeing this issue?
Tom
On 2/5/08 11:06 PM, Thomas D. Uram wrote:
> - That problem won't be identified in the VenueClient.log file.
> - I think I know the problem, it's with code for detecting input ports
> on the devices. If I'm right, it's a Windows-specific problem. I'll
> check tomorrow.
> - Logfiles are written to the user's directory because that's where
> the user can most likely write files. There may be instances in which
> the 'system' Logs directory will be written to, but it's not the usual
> case.
> I'll send a follow up when I have some information.
> Tom
> On 2/5/08 9:44 PM, Alex.Krumm-Heller at csiro.au wrote:
>> Hi Jason,
>> Sorry I should have included the information in the original email. I
>> am running on WindowsXP and the camera is a Logitech Quickcam
>> Communicate Deluxe. It seems from bit more investigation that vic
>> also crashes when it is just a video consumer as well.
>> I have taken a look at the logs and the relevant section from the
>> videoconsumer log seems to be:
>> 02/06/08 14:38:19 4932 Toolkit videoconsumerservice.py:186 INFO
>> Starting VideoConsumerService
>> 02/06/08 14:38:19 4932 Toolkit videoconsumerservice.py:187 INFO
>> executable = C:\Documents and Settings\Owner\Application
>> Data\AccessGrid3\local_services\VideoConsumerService\vic.exe
>> 02/06/08 14:38:19 4932 Toolkit videoconsumerservice.py:188 INFO
>> options = ['-C', u'Asia Pacific Access Grid Lobby', '-t', '127',
>> u'-XrtpName=CSIRO CTW2', u'-XrtpEmail=ict at csiro.au', '-XrecvOnly=1',
>> '-XsiteDropTime=5', '-Xgeometry=500x500', u'-Xtile=2',
>> u'233.2.178.9/17018']
>> 02/06/08 14:38:19 4932 ProcessManager processmanager.py:62 DEBUG
>> Creating process: C:\Documents and Settings\Owner\Application
>> Data\AccessGrid3\local_services\VideoConsumerService\vic.exe -C "Asia
>> Pacific Access Grid Lobby" -t 127 "-XrtpName=CSIRO CTW2"
>> -XrtpEmail=ict at csiro.au -XrecvOnly=1 -XsiteDropTime=5
>> -Xgeometry=500x500 -Xtile=2 233.2.178.9/17018
>> 02/06/08 14:38:19 4932 ProcessManager processmanager.py:75 DEBUG
>> Create process returns: (<PyHANDLE:780>, <PyHANDLE:784>, 4308, 5404)
>> 02/06/08 14:38:27 688 ProcessManager processmanager.py:138 ERROR
>> couldn't shutdown process <PyHANDLE:780>: (1444, 'PostThreadMessage',
>> 'Invalid thread identifier.')
>> Traceback (most recent call last):
>> File
>> "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\ProcessManager.py",
>> line 131, in TerminateProcess
>> win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
>> error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
>> 02/06/08 14:38:27 688 ProcessManager processmanager.py:145 ERROR
>> couldn't terminate process <PyHANDLE:780>: (5, 'TerminateProcess',
>> 'Access is denied.')
>> File
>> line 142, in TerminateProcess
>> win32process.TerminateProcess(pid, 0)
>> error: (5, 'TerminateProcess', 'Access is denied.')
>> 02/06/08 14:38:28 5540 Toolkit agservice.py:270 INFO Shut
>> service down
>> By the way, does anybody know why there is a "Logs" directory created
>> under the install directory (which on my system is C:\Program
>> Files\AGTk-3) if the logs appear in another location is this a bug or
>> is it intentional?
>> Alex
>> *From:* Jason Bell [mailto:j.bell at cqu.edu.au]
>> *Sent:* Wednesday, 6 February 2008 1:54 PM
>> *To:* Krumm-Heller, Alex (ICT Centre, Marsfield); ag-tech at mcs.anl.gov
>> *Subject:* RE: [AG-TECH] AG3.1 vic crashes
>> G'day Alex
>> Just wondering if you could provide some more information please.
>> · Operating System;
>> · Does "vic" work, if you are not transmitting? IE, just a
>> video Consumer.
>> · Do you have a model type for the Camera?
>> Additionally, logs can generally be found within C:\Documents and
>> Settings\<username>\Application Data\AccessGrid3\Logs
>> Hope this helps.
>> Cheers,
>> Jason.
>> *From:* Alex.Krumm-Heller at csiro.au [mailto:Alex.Krumm-Heller at csiro.au]
>> *Sent:* Wednesday, 6 February 2008 10:25 AM
>> *To:* ag-tech at mcs.anl.gov
>> *Subject:* [AG-TECH] AG3.1 vic crashes
>> I have just upgraded my installation of AccessGrid from 3.0.2 to 3.1.
>> When running the new version as soon as I create a videoconsumer node
>> service to capture from my Logitech webcam vic crashes. Can anyone
>> point me to where logs are generated to try and track down the problem.
>> Thanks
>> Alex
>> Jason Bell, B.I.T.
>> B. Info. Tech. (Honours) Student
>> High Performance Computing Support Officer,
>> Network Engineer
>> Information Technology Division
>> Central Queensland University
>> E-mail : j.bell at cqu.edu.au
>> Work : 07 4930 9229
>> Mobile : 0409 630897
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080207/e2e03747/attachment.htm>
