[AG-TECH] HD on AG
    Douglas Kosovic
    douglask at itee.uq.edu.au
    Sun Dec 21 23:21:13 CST 2008
Hi Gurcharan,
> I'm trying out the ucl vic you modified to render 1920x1080. I'm
> looking at it via VNC so it's
> limited but when i'm getting looks like standard definition in terms
of
> resolution (720x480)
> no matter what codec (mp4, h264, 261as) i use and no matter what the
> size is set to (small, med, large).
> any thoughts?
I just assumed the low res look was encoding artefacts as the best I
could get was just 6.6 fps @ 110kbps on a 2 x dual core 2.6 GHz Xeon
MacPro.
I'm on leave tomorrow, but might look at it when I get back next month,
as well as trying to get the existing raw codec (i.e uncompressed video)
working.
> PS for devices i get NTSC, 720, and 1080. i also get 59.95 for the
> frame rate from the HDMI card. (i get this with ultragrid, too). Any
> idea why? instead of 29.9?
I'm not sure why it's 59.95fps on the Mac and 29.97PsF (i.e. Progressive
Segmented Frame) on Windows, other than it's just the string that the
Quicktime Sequence Grabber VDig for that card returns.
Cheers,
Doug
> Douglas Kosovic wrote:
> > Hi Gurcharan,
> >>>> Really? Wow. You mean I can get vic to do uncompressed HD just
> like
> >>>> that? I've spent months trying to get UltraGrid to work on Macs
(I
> >>>> got it working on colleagues machines but not mine!). But the
goal
> >>>> was always to integrate it with the AG later. If this could be
> done
> >>>> now..........hmmmmmm....that would be the answer I've been
waiting
> >>>> for.
> >>> MacOS X vic can grab uncompressed video frames from the Blackmagic
> >>> HDMI capture card and then encode using whatever codec is
selected.
> >>> For uncompressed HD transsmission, I modified vic to add
OptIPortal
> >>> SAGE support but there were a number of overheads which resulted
in
> >>> only 21fps at ~700Mbps.
> >>> I wrote a simple stand-alone MacOS X SAGE application that was
> >>> achieving 25fps 1080i at ~930Mbps from a 25fps 1080i HDMI
> camcorder.
> >>>> So, can somebody kind do this quickly and let me try it out? I
> > could
> >>>> eventually get someone to do this but it would be from scratch in
> >>>> terms of their experience with this software.
> >>>> If this works it would be so great and save so many hours of work
> >> for
> >>>> me.
> >>> Did you want a modified MacOS X vic executable with 'large' set to
> >>> 1920x1080?
> >> oh yes, please. that would be a wonderful Xmas present!
> >> uncompressed HD in vic, yes. we can talk about compression later
> > Sorry to disappoint, the uncompressed HD video modification I
> mentioned
> > in my previous email was for use with SAGE, you can't just use
> another
> > vic and receive the uncompressed HD stream.
> > Find a zip file in the URL below that contains a modified vic (for
> Intel
> > MacOS X) that uses 1920x1080 for large, it'll encode in whatever
> codec
> > is selected in vic:
> >   http://www.vislab.uq.edu.au/ag3/macosx/
> > Unfortunately this modified VIC when used with 1920x1080 seems
pretty
> > sluggish.
> > Cheers,
> > Doug
> Gurcharan S. Khanna, Ph.D.
> Director of Research Computing
> Office of the Vice President for Research
> http://rc.rit.edu
> Assistant Research Professor, Ph.D. Program
> Golisano College of Computing and Information Sciences
> http://people.rit.edu/gskpop
> Director, Interactive Collaboration Environments Laboratory,
> Center for the Advancing the Study of Cyberinfrastructure
> http://icelab.rit.edu
> Rochester Institute of Technology
> 1 Lomb Memorial Drive
> Rochester, New York 14623-5603
> Phone: 585-475-7504  ~  Cell: 585-451-8370
> Email: gurcharan.khanna at rit.edu
