[AG-TECH] HD on AG
    Gurcharan S. Khanna
    gskpop at cis.rit.edu
    Sun Dec 21 00:01:18 CST 2008
Doug,
I'm trying out the ucl vic you modified to render 1920x1080. I'm looking
at it via VNC so it's
limited but when i'm getting looks like standard definition in terms of
resolution (720x480)
no matter what codec (mp4, h264, 261as) i use and no matter what the
size is set to (small,
med, large).
any thoughts?
thanks,
-gurcharan
PS for devices i get NTSC, 720, and 1080. i also get 59.95 for the frame
rate from the HDMI
card. (i get this with ultragrid, too). any idea why? instead of 29.9? -gsk
Douglas Kosovic wrote:
> Hi Gurcharan,
>>>> Really? Wow. You mean I can get vic to do uncompressed HD just like
>>>> that? I've spent months trying to get UltraGrid to work on Macs (I
>>>> got it working on colleagues machines but not mine!). But the goal
>>>> was always to integrate it with the AG later. If this could be done
>>>> now..........hmmmmmm....that would be the answer I've been waiting
>>>> for.
>>> MacOS X vic can grab uncompressed video frames from the Blackmagic
>>> HDMI capture card and then encode using whatever codec is selected.
>>> For uncompressed HD transsmission, I modified vic to add OptIPortal
>>> SAGE support but there were a number of overheads which resulted in
>>> only 21fps at ~700Mbps.
>>> I wrote a simple stand-alone MacOS X SAGE application that was
>>> achieving 25fps 1080i at ~930Mbps from a 25fps 1080i HDMI camcorder.
>>>> So, can somebody kind do this quickly and let me try it out? I
> could
>>>> eventually get someone to do this but it would be from scratch in
>>>> terms of their experience with this software.
>>>> If this works it would be so great and save so many hours of work
>> for
>>>> me.
>>> Did you want a modified MacOS X vic executable with 'large' set to
>>> 1920x1080?
>> oh yes, please. that would be a wonderful Xmas present!
>> uncompressed HD in vic, yes. we can talk about compression later :-)
> Sorry to disappoint, the uncompressed HD video modification I mentioned
> in my previous email was for use with SAGE, you can't just use another
> vic and receive the uncompressed HD stream.
> Find a zip file in the URL below that contains a modified vic (for Intel
> MacOS X) that uses 1920x1080 for large, it'll encode in whatever codec
> is selected in vic:
>   http://www.vislab.uq.edu.au/ag3/macosx/
> Unfortunately this modified VIC when used with 1920x1080 seems pretty
> sluggish.
> Cheers,
> Doug
Gurcharan S. Khanna, Ph.D.
Director of Research Computing
Office of the Vice President for Research
http://rc.rit.edu
Assistant Research Professor, Ph.D. Program
Golisano College of Computing and Information Sciences
http://people.rit.edu/gskpop
Director, Interactive Collaboration Environments Laboratory,
Center for the Advancing the Study of Cyberinfrastructure
http://icelab.rit.edu
Rochester Institute of Technology
1 Lomb Memorial Drive
Rochester, New York 14623-5603
Phone: 585-475-7504  ~  Cell: 585-451-8370
Email: gurcharan.khanna at rit.edu
http://rc.rit.edu
