[AG-TECH] HD on AG
    Luc Renambot
    renambot at uic.edu
    Mon Dec 15 09:39:41 CST 2008
On Dec 14, 2008, at 11:12 PM, Gurcharan S. Khanna wrote:
> Doug,
> Really? Wow. You mean I can get vic to do uncompressed HD just like
> that?
> I've spent months trying to get UltraGrid to work on Macs (I got it
> working on
> colleagues machines but not mine!). But the goal was always to
> integrate it with
> the AG later. If this could be done now..........hmmmmmm....that
> would be the
> answer I've been waiting for.
I think the  Ultragrid version from Csnet/ Masaryk univ. works on Mac:
   https://sitola.fi.muni.cz/igrid/index.php/UltraGrid
Luc Renambot
renambot at uic.edu                 Electronic Visualization Lab (M/C 152)
EVL Phone (312) 996-3002    University of Illinois at Chicago
EVL FAX   (312) 413-7585      851 S. Morgan St. Room 1120 SEO
http://www.evl.uic.edu/luc        Chicago, IL 60607-7053
> So, can somebody kind do this quickly and let me try it out? I could
> eventually
> get someone to do this but it would be from scratch in terms of
> their experience
> with this software.
> If this works it would be so great and save so many hours of work
> for me.
> Anyone?
> Thanks so much!
> -gurcharan
> Douglas Kosovic wrote:
>> Hi,
>>>>>> I, too, am extremely interested in vic supporting HD formats,
>>>>>> (including uncompressed!) One of the issues is the encoding
>>>>>> latency problem. Not sure there's a nice low latency encoding
>>>>>> solution out there yet. Alternatively, we might look at cheap
>>>>>> hardware encoders as the answer or HDMI cards to take the input
>>>>>> from the camera.
>>>>>> Can vic be made to take the output of, say, the BlackMagic
>>>>>> Design HDMI card on a Mac?
>> MacOS X UCL vic works out of the box with the BlackMagic Design
>> HDMI capture card, but gets scalled down to 640x480 for the large
>> capture option.
>> A quick hack to add 1980x1080 support is to modify the following
>> width & height lines in video/grabber-macosx.cpp :
>>   switch (decimate_) {
>>               case 1: // full-sized
>>                       width_ = SP601_NTSC_WIDTH;
>>                       height_ = SP601_NTSC_HEIGHT;
>> to:
>>                       width_ = 1920;
>>                       height_ = 1080;
>> Windows UCL vic on the other hand crashes with the BlackMagic
>> Design HDMI capture card as it currently doesn't support the
>> BlackMagic YUV colorspace.
>> I wouldn't mind adding support for USB HD camcorders that support
>> UVC (USB Video Class) H.264 streaming over USB, but I currently
>> don't have access to one. Note: Not all USB based camcorders
>> support UVC (e.g. Sony Hanycams).
>>>>>> I am currently using AGDV under windows but would like to move
>>>>>> to linux and use the HDV/DV linux vic for the DV part; i don't
>>>>>> think it's encoding the HDV, just accepting it as input from
>>>>>> the camera already encoded??? [chris?]
>>>>> It is possible to just packetise the compressed data from a
>>>>> camera, though as Chris points out it tends to have quite high
>>>>> latency. That is why the ultragrid and derivatives used
>>>>> uncompressed HD as their sources. VIC doesn't currently support
>>>>> mpeg2 nor does support packetisation of an existing compressed
>>>>> mpeg2 stream.
>>>> wait, i thought chris' vic supported HDV, which i assume is mp4???
>>> AFAIK most cameras support HDV - which is closely related to MPEG-2:
>>> http://en.wikipedia.org/wiki/HDV#HDV_720p
>> Mostly just the DV firewire based camcorders, the harddisk USB
>> based ones are now mostly AVCHD (MPEG-4 AVC/H.264).
>>>> also, how hard/easy would it be for vic to support packetizing
>>>> uncompressed HD?
>>> Not that hard - one needs to read the [RTP and codec] specs and
>>> code it up - or borrow someone else's....
>>> Piers.
>>>> -gurcharan
>>>>> Piers
>>>>>> My ideal would be to encode the presenter's laptop output and
>>>>>> deliver that as just another video stream along side the
>>>>>> presenter's video and the audience video and have autoplace lay
>>>>>> them out nicely in a framed window, a la Adobe Connect or
>>>>>> similar products, so the presenter, the slides, and additional
>>>>>> commentary could be nicely recorded for later videoon demand
>>>>>> playback.
>>>>>> Just my opinion (and need),
>>>>>> -gurcharan
>>>>>> Piers O'Hanlon wrote:
>>>>>>> Hi Derek,
>>>>>>> In principle VIC should be able encode and decode HD video -
>>>>>>> using one of the codecs that support such resolutions e.g. H.
>>>>>>> 264 or h261as.
>>>>>>> One needs to modify some of the configuration code in VIC to
>>>>>>> allow selection of larger resolutions (ie HD one needs
>>>>>>> something from 720p (1024x720) upwards). And of course an HD
>>>>>>> source is necessary. We don't currently have access to any HD
>>>>>>> kit so haven't had a chance to work on it but anyone is
>>>>>>> welcome to try!
>>>>>>> Cheers,
>>>>>>> Piers
>>>>>>> 2008/10/22 Vine, Derek A <Derek.Vine at usd.edu>:
>>>>>>>> Hello all,
>>>>>>>> I am doing some research to spec. up a new AG room, and the
>>>>>>>> group with the money is interested in HD video.  I see that
>>>>>>>> The University of Queensland has an HDV/DV VIC for Linux
>>>>>>>> based systems already, but we would like to stay with Windows.
>>>>>>>> I was just wondering what kind of time frame I can give them
>>>>>>>> as to when HD will be supported in AG on Windows.  In
>>>>>>>> particular, an HD VIC that will  take its video from a
>>>>>>>> capture card with an HD-SDI input, like the one attached in
>>>>>>>> the PDF.
>> I didn't see the PDF, what colorspace does it support? If it's YUV
>> 4:2:0, it would probably work with this vic:
>> http://www.vislab.uq.edu.au/ag3/windows/vic-20081121.zip
>> (which contained a fix for 480i DV white line artifacts)
>> Anyway, I started working on adding support for more colorspaces to
>> the Windows code a few weeks ago and I might get back to working on
>> the code soon.
>>>>>>>> Thank you in advance for your help.
>>>>>>>> Derek Vine
>>>>>>>> Communication Network Specialist
>>>>>>>> The University of South Dakota
>>>>>>>> 414 East Clark Street
>>>>>>>> Vermillion, SD 57069
>>>>>>>> (605) 677-8215
>>>>>>>> dvine at usd.edu
> Gurcharan S. Khanna, Ph.D.
> Director of Research Computing
> Office of the Vice President for Research
> http://rc.rit.edu
> Assistant Research Professor, Ph.D. Program
> Golisano College of Computing and Information Sciences
> http://people.rit.edu/gskpop
> Director, Interactive Collaboration Environments Laboratory,
> Center for the Advancing the Study of Cyberinfrastructure
> http://icelab.rit.edu
> Rochester Institute of Technology
> 1 Lomb Memorial Drive
> Rochester, New York 14623-5603
> Phone: 585-475-7504  ~  Cell: 585-451-8370
> Email: gurcharan.khanna at rit.edu
>> Hi,
>>>>>> from the camera.
>> capture option.
>> to:
>>                       width_ = 1920;
>>                       height_ = 1080;
>>>>> mpeg2 stream.
>>>> uncompressed HD?
>>> Piers.
>>>> -gurcharan
>>>>> Piers
>>>>>> playback.
>>>>>> -gurcharan
>>>>>>> Hi Derek,
>>>>>>> 264 or h261as.
>>>>>>> welcome to try!
>>>>>>> Cheers,
>>>>>>> Piers
>>>>>>>> Hello all,
>>>>>>>> the PDF.
>> the code soon.
>>>>>>>> Derek Vine
>>>>>>>> (605) 677-8215
>>>>>>>> dvine at usd.edu
> http://rc.rit.edu
