[AG-TECH] how do I get desktop audio 'into' AG/RAT?
Andrew Leahy
alfski at gmail.com
Tue Aug 26 03:25:51 CDT 2008
Ta.
BTW just found with RAT under Windows you can change the Input to 'Stereo
Mix' which grabs the local audio output rather than the Mic In. So using
this along with VPCScreenProducer provides a basic way for users want to
push media from a Windows desktop.
Cheers, Andrew
2008/8/26 Jason Bell <j.bell at cqu.edu.au>
> G'day Andrew
> One simply solution I have used in the past, is to use the separate
> computer (ie presenter machine) which has the AG software on it which allows
> you to transmit the desktop or window using VPCScreen, or alternatively, if
> you VNC to the presenter machine, you can then VPCSreen the VNC session.
> Given this is a separate machine, you connect the audio output from the
> computer to the Echo Canceller, this then allows you to transmit the audio
> both locally and externally. I have done this a number of times, especially
> for multimedia presentations.
> I hope this gives you an idea for one possible solution.
> Cheers,
> Jason.
> *From:* Andrew Leahy [mailto:alfski at gmail.com]
> *Sent:* Monday, 25 August 2008 2:30 PM
> *To:* ag-tech
> *Subject:* [AG-TECH] how do I get desktop audio 'into' AG/RAT?
> Hi - this is a tough one because of all the echo/feedback problems.
> How do sites capture audio from applications on a AG desktop and get it
> into the AG environment?
> For example, if I want to share desktop multimedia I can use
> VPCScreenProducer to inject the video into VIC.
> But what do I do about audio? the normal audio-out is echo cancelled by the
> ClearOne or similar device so isn't transmitted into RAT.
> One idea, that I haven't tried, is to use a second sound device and feed it
> into the ClearOne or room to be picked up by the line/mic-in on the primary
> card (where RAT is recording)? But then I have the hassle of figuring how to
> tell particular apps to use device 2 rather than device 1 for audio.
> My application is with Linux (FC) desktops, but the same problem would
> apply to Windows & OS X.
> Any advice would be welcome.
> Cheers, Andrew
> School of Computing & Mathematics
> University of Western Sydney
Resistance is Fertile
My Household Average Daily Consumption - Occupants: 1.5 adults
Water:128L Electricity:6.2kWh Petrol:1.9L Gas:0kJ
NABERS Home Rating: Energy 4.5 stars, Water 5 stars
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080826/0eb8986d/attachment.htm>
