[AG-TECH] Equiptment ideas?
Matthew Leszczenski
mxl9499 at rit.edu
Mon Aug 11 14:53:19 CDT 2008
I have looked at the RAV 600, and that is more for a full room node, whereas
this node is in a public space, so the table microphones would not work as
well to pick up just the sound we want, compared to the ambient noise around
it, and unfortunately the RAV 600 has its own proprietary connection for its
microphones to the main system, so it cannot be expanded upon except with
other ClearOne microphones directly made for the RAV systems. Thank you
though!
Matthew Leszczenski
- Technical Assistant and Eagle Scout
- Undergraduate NSSA Major @ RIT
- Collaboration Technology Developer @ RIT Research Computing department
Sent: Monday, August 11, 2008 3:06 PM
To: Matthew Leszczenski; ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] Equiptment ideas?
Hi Matthew,
Check out the RAV 600:
http://www.clearone.com/revolutionary-audio-conferencing.html .
Quang Tran
LSUHSC
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Matthew Leszczenski
Sent: Monday, August 11, 2008 1:20 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Equiptment ideas?
Hello all,
One of my current projects is a public AG kiosk-like setup,
in which people will be able to walk up to the node, choose a stream and
start to talk directly with that stream. The area is about a 12' X 12'
square area, with drop-tile ceiling, it will consist of 1x HD camera, 1x DV
camera, 2x 52" HD LCD TV's, 1x high quality microphone, some sort of
directional speakers, and an echo cancellation system. It seems that I
would only need one microphone input for this project. However I have mostly
worked with the ClearOne XAP400, which is a dual line-in echo cancellation
system, and the XAP does not seem to come in a single line-in version. Is
there some other echo cancellation unit that people would suggest for a
setup like this? Or have I missed a single line-in version of the XAP? Also
any other suggestions for the node would be nice to hear, in case others
have ideas that haven't been thought of, or others are thinking of building
a node such like this.
As always all help is appreciated!
Matthew Leszczenski
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080811/7646e368/attachment.htm>
