[AG-TECH] Equiptment ideas?
    Tran, Quang V.
    qtran3 at lsuhsc.edu
    Mon Aug 11 14:06:02 CDT 2008
Hi Matthew,
Check out the RAV 600:
http://www.clearone.com/revolutionary-audio-conferencing.html .
Quang Tran
LSUHSC
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Matthew Leszczenski
Sent: Monday, August 11, 2008 1:20 PM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Equiptment ideas?
Hello all,
                One of my current projects is a public AG kiosk-like
setup, in which people will be able to walk up to the node, choose a
stream and start to talk directly with that stream. The area is about a
12' X 12' square area, with drop-tile ceiling, it will consist of 1x HD
camera, 1x DV camera, 2x 52" HD LCD TV's, 1x high quality microphone,
some sort of directional speakers, and an echo cancellation system.  It
seems that I would only need one microphone input for this project.
However I have mostly worked with the ClearOne XAP400, which is a dual
line-in echo cancellation system, and the XAP does not seem to come in a
single line-in version. Is there some other echo cancellation unit that
people would suggest for a setup like this? Or have I missed a single
line-in version of the XAP? Also any other suggestions for the node
would be nice to hear, in case others have ideas that haven't been
thought of, or others are thinking of building a node such like this.
As always all help is appreciated!
Matthew Leszczenski
 - Technical Assistant and Eagle Scout
 - Undergraduate NSSA Major @ RIT
 - Collaboration Technology Developer @ RIT Research Computing
department
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080811/0f90c1b7/attachment.htm>
