[AG-TECH] Any more H.264 news?
Thomas D. Uram
turam at mcs.anl.gov
Fri Apr 11 13:08:58 CDT 2008
Andrew:
Please give some more detail of exactly the problem you're seeing.
There is code in the AG services to counter some of the mapping problems
with these devices, but with changes in vic and uncertainty about which
drivers you're using, and lacking a description of the problem, I can't
for certain know what's going wrong for you.
Tom
On 4/11/08 12:18 PM, Andrew Ford wrote:
> Also, I forgot to add that this new SUMOVER vic also has the
> videum-port-changing bug - unfortunately I can't seem to find the old
> page for it - meaning that this vic code presumably does not include
> some bugfixes (that became part of "AG vic", I think) from nearly a
> year ago (!)
> --Andrew
> On Wed, Apr 2, 2008 at 3:14 PM, Andrew Ford <acf0659 at rit.edu
> <mailto:acf0659 at rit.edu>> wrote:
> The only major issues that we're seeing revolve around firewire/dv
> support. On Windows, firewire capture shows flashing vertical
> white lines (as has probably already been mentioned on the list),
> and on Linux (Ubuntu) vic can't see any firewire devices, and I
> have the device permissions set correctly as far as I can tell so
> I don't think the problem would be on my end. I'm guessing that
> the Linux issue is due to the current Linux packages (from Chris
> at UQ) not actually including the "enhanced vic" code that
> supports DV and was developed at UQ, but rather just the new
> h.264-supporting code from SUMOVER. Is this correct, and if so,
> will these codebases be merged?
> --Andrew
> On Mon, Mar 31, 2008 at 1:14 PM, Thomas D. Uram <turam at mcs.anl.gov
> <mailto:turam at mcs.anl.gov>> wrote:
> Service packages for Mac OSX have been added to the project
> web page referenced below. Note that the embedded vic
> executables will work on either Intel or PPC Macs.
> Again, please report problems liberally so we can improve this
> support.
> Tom
> On 2/27/08 6:03 PM, Thomas D. Uram wrote:
>> Jimmy:
>> A beta version of the h264/mpeg4 services can be gotten from
>> here:
>> http://www.accessgrid.org/project/Sumover
>> Note that it is currently only for Windows. I'll work to get
>> the Mac version up. I expect that Doug/Chris will provide
>> Linux support very soon.
>> Also note that if you are using these services to send
>> mpeg4/h264, anyone who does not have the mpeg4/h264 consumer
>> service installed will not be able to see your video.
>> Please report problems liberally so we can improve this support.
>> Tom
>> On 1/28/08 5:17 PM, Jimmy Miklavcic wrote:
>>> Has there been any more progress with H.264 and AG 3.1? Also
>>> has anyone seen the new Osprey 700 HD?
>>> Jimmy
>>> Jimmy Miklavcic
>>> Multimedia Specialist
>>> Jimmy.Miklavcic at utah.edu <mailto:Jimmy.Miklavcic at utah.edu>
>>> UNIVERSITY OF UTAH
>>> CTR FOR HIGH PERFORM COMPUTING
>>> 155 SOUTH 1452 EAST RM 405
>>> SALT LAKE CITY, UT 84112-0190
>>> Office: 801.585.9335
>>> Fax: 801.585.5366
>>> http://www.anotherlanguage.org
>>> <http://www.anotherlanguage.org/>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080411/2e265a2e/attachment.htm>
