James Miller wrote: > Ahhhh figured it out. I edited the .RATdefaults file in my home directory. > -J > I believe if you press the 'Quit' button in the bottom right corner of RAT (NOT the x in the upper right corner!!) it will write the current settings to the .RATdefaults file for you. Then, just restart your audio and it should stick. Cheers, Todd
