[AG-TECH] proxies, firewalls, and searching mailing lists
George Estes
gestes at ncsa.uiuc.edu
Wed Sep 26 12:48:09 CDT 2007
Tom,
I have K12 AG users that have to supply a password to their proxy server. Does this mean that even S \(Sambid\) Shrestha's solution is not going to help these users. One reason I ask is they've tried it and it doesn't work for them.
Does AG 3.1 deal with this problem?
George
At 09:37 AM 5/24/2006 -0500, Thomas D. Uram wrote:
>Daniel McBrearty wrote:
>>Hi
>>Just been looking at AG as a possible toolkit to use for an app we are working on.
>>We just worked through the install instructions for winxp ( http://www.accessgrid.org/?q=node/17 <http://www.accessgrid.org/?q=node/17> ), no problem.
>>Unfortunately we are stuck behind a proxy that needs authentication. Found out how to config the proxy; but there seems to be noway to set up auth ... am I right?
>Do you mean that you have to provide a password to the proxy server? If so, there is no way to do that currently.
>We've never had a user raise this issue. Are there others on the list with a similar problem?
>>(I'd have searched for these questions in the lists, but there seems to be no simple way to actually do that ... ?)
>You can search the mailing lists using the form at the bottom of the Mailing Lists page on AccessGrid.org:
>http://www.accessgrid.org/?q=mailinglists
>I just added the form this week, so it's no surprise you didn't find it before.
>Tom
