[AG-TECH] Is PING required?
Thomas D. Uram
turam at mcs.anl.gov
Wed Oct 17 12:23:07 CDT 2007
Hi Ben:
The short answer is that it is not required for any of the components
you've specified, as of 3.0.2, and will not be for 3.1.
'ping' was used prior to 3.0.2 for examining the reachability of
bridges. As of 3.0.2, it was replaced by an RPC call over TCP. You'll
see code in RegistryClient.py that still uses the 'ping' method, but
that is only for pre-3.0.2 bridges and will be removed before long.
Tom
On 10/17/07 11:19 AM, Ben Green wrote:
> Can someone please clarify whether the firewall must allow inbound/outbound ICMP 'echo request' in the following cases, respectively:
> AG Toolkit client v3.02
> AG Toolkit VenueServer v3.02
> AG Toolkit BridgeServer v3.02
> ...and also for the forthcoming v3.1 as well.
> Cheers, Ben.
> | Ben Green |
> | Access Grid Support Centre |
> | Room G49-H |
> | Research Computing Services |
> | Kilburn Building |
> | University of Manchester |
> | Oxford Road |
> | Manchester |
> | M13 9PL |
> | Tel. 0161 306 6621 |
> | Fax. 0161 275 0637 |
> | ben.green at manchester.ac.uk |
> | http://www.agsc.ja.net |
