[AG-TECH] Vic Source issue - Multiple Producers
Todd Zimmerman
toddz at sfu.ca
Mon Oct 1 16:00:46 CDT 2007
Douglas Kosovic wrote:
> You could try the vic-2.8ucl1.3.0-0.1.20070816svn.el5 RPM instead. I
> built some i386 RHEL5/CentOS5 AG RPMs a few days ago:
> http://www.vislab.uq.edu.au/accessgrid3/centos/
> or the symlink:
> http://www.vislab.uq.edu.au/accessgrid3/rhel/
> 'dmesg' might give some indication of what's going on.
New EL vic has same behaviour - no messages in dmesg.
Didn't update the entire AG (just Vic) due to conflicts with epel and some installed software - but,
same behavior when running multiple vics manually.
> On RHEL5, try installing a kernel-2.6.22 RPM from Fedora Core6 updates
> and see if you get the same symptoms with the V4L that comes with the
> newer kernel.
May just go to Fedora - and will email if problem still exists.
Todd
