[AG-TECH] Rat and MBUS problems
Lassi Ylikojola
lapeyl at uwasa.fi
Sun May 27 20:28:07 CDT 2007
Hi !
Good to hear You got it working.
Actually only oss-emulation works for my m-audio card. Alsa is still a
problem.
It's ticket #74 at sumover.
Lassi
Quoting Jeremy Mann <jeremymann at gmail.com>:
> Switching to SUMOVER RAT, all of our problems went away. I found it
> odd that it used to work up until a few days ago.
> On 5/24/07, Lassi Ylikojola <lapeyl at uwasa.fi> wrote:
>> Hi !
>> I used to have this problem with rat 4.2.22 on fedora 6 64-bit em64t
>> with m-audio 2496 / ice1712 card.
>> The way i 'fixed' it was I installed old soundblaster card on the same
>> machine and even if it was not default the mixer would start to work
>> on m-audio.
>> Anyway never rat from SUMOVER and alsa 1.0.14-0.1.rc1 works for me.
>> You have to remove the -S option lines from AudioService.py to use
>> SUMOVER rat.
>> Lassi
>>> On 5/23/07, Colin Perkins <csp at csperkins.org> wrote:
>>>> Mbus problems are often due to a host firewall blocking UDP port
>>>> 47000. Did you enable a different firewall configuration when rebooting?
>>> No, no firewalls on either machine. The odd thing was thing was that I
>>> replaced the soundcard in one Linux machine and the MBUS errors went
>>> away. I'm now trying to use the SUMOVER's version of RAT to see if
>>> that fixes the other clients.
