[AG-TECH] Rat and MBUS problems
Jeremy Mann
jeremymann at gmail.com
Thu May 24 08:28:15 CDT 2007
Switching to SUMOVER RAT, all of our problems went away. I found it
odd that it used to work up until a few days ago.
On 5/24/07, Lassi Ylikojola <lapeyl at uwasa.fi> wrote:
> Hi !
> I used to have this problem with rat 4.2.22 on fedora 6 64-bit em64t
> with m-audio 2496 / ice1712 card.
> The way i 'fixed' it was I installed old soundblaster card on the same
> machine and even if it was not default the mixer would start to work
> on m-audio.
> Anyway never rat from SUMOVER and alsa 1.0.14-0.1.rc1 works for me.
> You have to remove the -S option lines from AudioService.py to use
> SUMOVER rat.
> Lassi
> Quoting Jeremy Mann <jeremymann at gmail.com>:
> > On 5/23/07, Colin Perkins <csp at csperkins.org> wrote:
> >> Mbus problems are often due to a host firewall blocking UDP port
> >> 47000. Did you enable a different firewall configuration when rebooting?
> > No, no firewalls on either machine. The odd thing was thing was that I
> > replaced the soundcard in one Linux machine and the MBUS errors went
> > away. I'm now trying to use the SUMOVER's version of RAT to see if
> > that fixes the other clients.
