[AG-TECH] Errors in install Bonjour python moudle.
Thomas Uram
turam at mcs.anl.gov
Thu May 24 12:05:06 CDT 2007
Hi:
>From the Windows Bonjour README file:
This directory contains support files for running mDNS on Microsoft
Windows
and Windows CE/PocketPC. Building this code requires the Windows SDK
or later.
It looks like you're using VC98, so you'll have to use VC2003 instead.
Tom
On 5/24/07 3:10 AM, 刘冠强 wrote:
> Hi:
> I have installed Bonjour and Bonjour SDK.
> Buti when I run "python setup.py build " in dir bonjour.
> There are errors:
> E:\eclipse-project\bonjour>python setup.py build
> incDirList = ['c:\\program files\\bonjour sdk\\include']
> Running swig with: |['swig', '-python', '-outdir', 'bonjour',
> '-new_repr', '-IC:
> \\Python23\\include' <file://%5C%5CPython23%5C%5Cinclude%27>, '-o',
> 'bonjour_wrap.c', 'bonjour.i']|
> running build
> running build_py
> copying bonjour\__init__.py -> build\lib.win32-2.3\bonjour
> running build_ext
> building 'bonjour._bonjour' extension
> D:\Program Files\Microsoft Visual Studio\VC98\BIN\cl.exe /c /nologo
> /Ox /MD /W3
> /GX /DNDEBUG "-Ic:\program files\bonjour sdk\include"
> -IC:\Python23\include -IC:
> \Python23\PC /Tcbonjour_wrap.c
> /Fobuild\temp.win32-2.3\Release\bonjour_wrap.obj
> /DWIN32
> bonjour_wrap.c
> c:\program files\bonjour sdk\include\dns_sd.h(67) : error C2061:
> syntax error :
> identifier 'uint8_t'
> c:\program files\bonjour sdk\include\dns_sd.h(67) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(68) : error C2061:
> syntax error :
> identifier 'int8_t'
> c:\program files\bonjour sdk\include\dns_sd.h(68) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(69) : error C2061:
> syntax error :
> identifier 'uint16_t'
> c:\program files\bonjour sdk\include\dns_sd.h(69) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(70) : error C2061:
> syntax error :
> identifier 'int16_t'
> c:\program files\bonjour sdk\include\dns_sd.h(70) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2146:
> syntax error :
> missing ')' before identifier 'port'
> c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2081:
> 'uint16_t' : n
> ame in formal parameter list illegal
> c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2061:
> syntax error :
> identifier 'port'
> c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2059:
> syntax error :
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(658) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2146:
> syntax error :
> missing ')' before identifier 'rrtype'
> c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2081:
> 'uint16_t' : n
> c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2061:
> syntax error :
> identifier 'rrtype'
> c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2059:
> syntax error :
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(701) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2146:
> syntax error :
> missing ')' before identifier 'rdlen'
> c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2081:
> 'uint16_t' : n
> c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2061:
> syntax error :
> identifier 'rdlen'
> c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2059:
> syntax error :
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(740) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2146:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2081:
> 'uint16_t' : n
> c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2061:
> syntax error :
> identifier 'port'
> c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2059:
> syntax error :
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(934) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2146:
> syntax error :
> missing ')' before identifier 'callBack'
> c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2081:
> 'DNSServiceRes
> olveReply' : name in formal parameter list illegal
> c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2061:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2059:
> syntax error :
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(985) : error C2059:
> syntax error :
> c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2146:
> syntax error
> : missing ')' before identifier 'rrtype'
> c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2081:
> 'uint16_t' :
> c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2061:
> syntax error
> : identifier 'rrtype'
> c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1107) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2146:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2081:
> 'uint16_t' :
> c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2061:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1160) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2146:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2081:
> 'uint16_t' :
> c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2061:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1211) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2146:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2081:
> 'uint16_t' :
> c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2061:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1249) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2146:
> syntax error
> : missing ')' before identifier 'bufferLen'
> c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2081:
> 'uint16_t' :
> c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2061:
> syntax error
> : identifier 'bufferLen'
> c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1369) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2146:
> syntax error
> : missing ')' before identifier 'valueSize'
> c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2081:
> 'uint8_t' : n
> c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2061:
> syntax error
> : identifier 'valueSize'
> c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1431) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1469) : error C2143:
> syntax error
> : missing '{' before '__stdcall'
> c:\program files\bonjour sdk\include\dns_sd.h(1544) : error C2146:
> syntax error
> : missing ')' before identifier 'txtLen'
> c:\program files\bonjour sdk\include\dns_sd.h(1544) : error C2061:
> syntax error
> : identifier 'txtLen'
> c:\program files\bonjour sdk\include\dns_sd.h(1544) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1547) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1573) : error C2146:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1573) : error C2061:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1573) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1577) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1593) : error C2143:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1595) : error C2146:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1595) : error C2061:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1595) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1597) : error C2059:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1640) : error C2146:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1640) : error C2061:
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1640) : error C2059:
> syntax error
> syntax error
> c:\program files\bonjour sdk\include\dns_sd.h(1647) : error C2059:
> syntax error
> bonjour_wrap.c(2673) : error C2146: syntax error : missing ')' before
> identifier
> 'port'
> bonjour_wrap.c(2673) : error C2081: 'uint16_t' : name in formal
> parameter list i
> llegal
> bonjour_wrap.c(2673) : error C2061: syntax error : identifier 'port'
> bonjour_wrap.c(2673) : error C2059: syntax error : ';'
> bonjour_wrap.c(2673) : error C2059: syntax error : ','
> bonjour_wrap.c(2673) : fatal error C1003: error count exceeds 100;
> stopping comp
> ilation
> error: command '"D:\Program Files\Microsoft Visual
> Studio\VC98\BIN\cl.exe"' fail
> ed with exit status 2
> thanks!
> 刘冠强
> 2007-05-24
