[AG-TECH] MS LifeCam and AG
Mike.W.Daley at cs.cardiff.ac.uk
Thu May 17 21:29:59 CDT 2007
Thats strange I bought one of these a couple of months ago and it
worked straight out of the box with vic.
Mike
Quoting Michael Miller <mimiller at ncsa.uiuc.edu>:
> I had a little trouble getting my LifeCam to work with AG. Each time
> vic started it complained about a 640X480 res from the camera. Even
> setting the res in the LifeCam software didn't help. But I noticed
> that vic would transmit for a few seconds before crashing. So I
> restarted it and quickly went to the menu button and opened the vic
> menu dialog. Then released the camera. This gave me a chance to
> select the 'Configure on Transmit' option and make sure that the Device
> was set to 'Microsoft Image Capture'. Then when clicking 'transmit'
> again the camera driver dialogs come up letting you select 352X288 res
> and other settings. I found if you set the Device to '...LifeCam' the
> res settings don't stick and you have to run this process over again.
> So for my wishlist, can I add getting vic to handle bad res more
> gracefully. Vic should just stop transmitting and take you to the menu
> dialog so you can set things properly.
> hope this helps
This message was sent using IMP, the Internet Messaging Program.
