[AG-TECH] AG3 Bridge Problem [nclassified]
Kivshar, Boris (Contractor)
Boris.Kivshar at dsto.defence.gov.au
Wed May 9 18:19:45 CDT 2007
Thank you for the explanation Andrew. :-)
We are on an incredibly secure & strict network, so that means we don't
have access to the outside world. Therefore we have to use our own
registry and even our own jabber server for the chat. All the networks
ports are open. I am thinking it may have something to do with our
bridge registry, as I can't see my bridge server as being in that list
at any point in time. I will keep playing around and hopefully I may get
a little bit closed to the light at the end of the tunnel.
Thanks for your help.
Boris
From: Andrew A Rowley [mailto:Andrew.Rowley at manchester.ac.uk]
Sent: Wednesday, 9 May 2007 5:58 PM
To: Kivshar, Boris (Contractor); ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] AG3 Bridge Problem [nclassified]
It will probably work if you set
-registryURL=http://www.accessgrid.org/registry/peers.txt
There are actually three components in the bridge architecture in AG3.
These are the bridge registry, the bridge registry peer(s) and the
bridge servers. The registry holds a (currently static) list of
registry peers. The bridge server connects to the registry and gets
this list of peers. It then tries each one in the list until one works
and then registers itself with this peer. The client then connects to
the registry and gets the same list of peers and again tries each one
until one works. The client then gets the list of bridges from this
peer and shows you them (currently just 10 of them). You can run your
own registry and peer(s) but you would then need to change a hidden
configuration option in the client to point at your registry rather than
the ANL one (this will change in the next version where you will be able
to change this option in the client and even have multiple registries
specified).
Andrew :-)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Kivshar, Boris (Contractor)
Sent: 09 May 2007 02:23
To: Andrew.Rowley at manchester.ac.uk; ag-tech at mcs.anl.gov
Andrew,
Thank you for your time in answering my email.
The below log files all seem to be fine, I included them in this email
for anyone to take a look. My Bridge.log file seems to be rather empty.
Even with me trying to connect to the bridge and use it, which
afterwards i get an error messege it still remains empty.
"05/09/07 10:24:18 4384 Toolkit config.py:559 DEBUG System hostname
of XXXXXX is valid
05/09/07 10:24:18 4384 Toolkit toolkit.py:111 DEBUG Initializing AG
Toolkit version 3.0.2
05/09/07 10:24:18 4384 Toolkit toolkit.py:112 INFO Command and
arguments: ['Bridge3.py',
'--registryUrl=http://AAAAAAAAAAAAAAA:8080/AGBridgeRegistry/peers.txt',
'--name=NAME', '--location=LOCATION', '--qbexec=./QuickBridge.exe']
05/09/07 10:24:18 4384 VenueClient preferences.py:180 DEBUG
Preferences.LoadPreferences: open file
05/09/07 10:24:18 4384 Toolkit toolkit.py:161 INFO Logfile Name:
Bridge.log
05/09/07 10:24:18 4384 Toolkit toolkit.py:650 INFO Service init:
have profile None
05/09/07 10:24:18 4384 Toolkit toolkit.py:675 INFO Service
Initialization Complete.
05/09/07 10:24:18 4384 ProcessManager processmanager.py:27 WARNING
ProcessManager callback not yet implemented on Windows
05/09/07 10:24:18 4384 Toolkit bridgefactory.py:83 INFO Allocator
using port range: [50000, 52000]
05/09/07 10:24:18 4384 Toolkit bridgefactory.py:91 INFO
BridgeFactory.SetPortMin 50000
05/09/07 10:24:18 4384 Toolkit bridgefactory.py:95 INFO
BridgeFactory.SetPortMax 52000"
In my VenueServer.log nothing seems to be out of the ordinary. Would
these lines have any impact:
"05/09/07 11:03:08 3812 Security authorizationmanager.py:491 DEBUG
Adding Subject: /O=Access Grid/O=Argonne National Laboratory/OU=Futures
Lab Anonymous Authority/CN=Anonymous User
25d62b22190f5d94217615414cc8e236 to Role: Administrators
05/09/07 11:03:08 3812 Security authorizationmanager.py:503 WARNING
Not adding subject /O=Access Grid/O=Argonne National
Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User
25d62b22190f5d94217615414cc8e236 to role Administrators, it's already
there."
The bridge registry is on another machine, once I start my BridgeServer
script from my machine is it meant to add my bridge to the peers.txt
file?
Would it be worthwhile setting up another Bridge Registry to test
things? If so are there any documents posts about how to do so?
Boris.
Sent: Tuesday, 8 May 2007 6:15 PM
Take a look at the bridge.log file on the server (in C:\Documents and
Settings\<username>\Application Data\AccessGrid3\Logs) and in the
VenueClient.log on the client. These usually tell you what is going
wrong.
Andrew :-)
RSS Group,
Kilburn Building,
Oxford Road,
Manchester,
M13 9PL,
UK
Sent: 04 May 2007 01:21
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] AG3 Bridge Problem [nclassified]
Hey all,
In our organisation we have in one location a Venue Server, Bridge, and
a Bridge Registry which all works fine. In another location I am setting
up another venue server. So far I have successfully installed the
VenueServer, but my Bridge is not working. I run the Bridge server via a
batch file with the name, location and the bridge registry path of the
first Bridge Registry.
The script that I am running is:
Cd "C:\Program Files\AGTk-3\bin"
C:\Python23\python.exe Bridge3.py
--registryUrl=http://mybridgeregistryserver:8080/AGBridgeRegistry/peers.
txt --name=MyBridgeName
--location="My Location" --qbexec=./QuickBridge.exe
All the Venue Clients are able to see my new bridge but all get an error
message when they try and use it.
"Connection to the bridge <name> failed. Please use a different bridge"
The Bridge is being run on the same machine as the Venue server, and
even the client on that same machine comes up with that same error.
All the machine do not have connectivity to the internet.
Any advice would be much appriciated.
Boris
IMPORTANT: This email remains the property of the Australian Defence
Organisation and is subject to the jurisdiction of section 70 of the
CRIMES ACT 1914. If you have received this email in error, you are
requested to contact the sender and delete the email.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070510/aba08b79/attachment.htm>
