[AG-TECH] AG3 Bridge Problem [nclassified]
Beobkyun Kim
trugens at gmail.com
Tue May 8 21:00:13 CDT 2007
Hi.
Can I ask another question that related to this problem ?
I want to know how to run bridge registry server and how to get the software
for this service.
On 5/9/07, Kivshar, Boris (Contractor) <Boris.Kivshar at dsto.defence.gov.au>
wrote:
> Andrew,
> Thank you for your time in answering my email.
> The below log files all seem to be fine, I included them in this email
> for anyone to take a look. My Bridge.log file seems to be rather empty.
> Even with me trying to connect to the bridge and use it, which afterwards i
> get an error messege it still remains empty.
> *"05/09/07 10:24:18 4384 Toolkit config.py:559 DEBUG System hostname
> of XXXXXX is valid
> 05/09/07 10:24:18 4384 Toolkit toolkit.py:111 DEBUG Initializing AG
> Toolkit version 3.0.2
> 05/09/07 10:24:18 4384 Toolkit toolkit.py:112 INFO Command and
> arguments: ['Bridge3.py', '--registryUrl=
> http://AAAAAAAAAAAAAAA:8080/AGBridgeRegistry/peers.txt', '--name=NAME',
> '--location=LOCATION', '--qbexec=./QuickBridge.exe']
> 05/09/07 10:24:18 4384 VenueClient preferences.py:180 DEBUG
> Preferences.LoadPreferences: open file
> 05/09/07 10:24:18 4384 Toolkit toolkit.py:161 INFO Logfile Name:
> Bridge.log
> 05/09/07 10:24:18 4384 Toolkit toolkit.py:650 INFO Service init: have
> profile None
> 05/09/07 10:24:18 4384 Toolkit toolkit.py:675 INFO Service
> Initialization Complete.
> 05/09/07 10:24:18 4384 ProcessManager processmanager.py:27 WARNING
> ProcessManager callback not yet implemented on Windows
> 05/09/07 10:24:18 4384 Toolkit bridgefactory.py:83 INFO Allocator
> using port range: [50000, 52000]
> 05/09/07 10:24:18 4384 Toolkit bridgefactory.py:91 INFO
> BridgeFactory.SetPortMin 50000
> 05/09/07 10:24:18 4384 Toolkit bridgefactory.py:95 INFO
> BridgeFactory.SetPortMax 52000"*
> In my VenueServer.log nothing seems to be out of the ordinary. Would these
> lines have any impact:
> *"05/09/07 11:03:08 3812 Security authorizationmanager.py:491 DEBUG
> Adding Subject: /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
> Anonymous Authority/CN=Anonymous User 25d62b22190f5d94217615414cc8e236 to
> Role: Administrators
> 05/09/07 11:03:08 3812 Security authorizationmanager.py:503 WARNING
> Not adding subject /O=Access Grid/O=Argonne National Laboratory/OU=Futures
> Lab Anonymous Authority/CN=Anonymous User 25d62b22190f5d94217615414cc8e236
> to role Administrators, it's already there."*
> The bridge registry is on another machine, once I start my BridgeServer
> script from my machine is it meant to add my bridge to the peers.txt file?
> Would it be worthwhile setting up another Bridge Registry to test things?
> If so are there any documents posts about how to do so?
> Boris.
> *From:* Andrew A Rowley [mailto:Andrew.Rowley at manchester.ac.uk]
> *Sent:* Tuesday, 8 May 2007 6:15 PM
> *To:* Kivshar, Boris (Contractor); ag-tech at mcs.anl.gov
> *Subject:* RE: [AG-TECH] AG3 Bridge Problem [nclassified]
> Hi,
> Take a look at the bridge.log file on the server (in C:\Documents and
> Settings\<username>\Application Data\AccessGrid3\Logs) and in the
> VenueClient.log on the client. These usually tell you what is going
> wrong.
> Andrew J
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
> *From:* owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] *On
> Behalf Of *Kivshar, Boris (Contractor)
> *Sent:* 04 May 2007 01:21
> *To:* ag-tech at mcs.anl.gov
> *Subject:* [AG-TECH] AG3 Bridge Problem [nclassified]
> Hey all,
> In our organisation we have in one location a Venue Server, Bridge, and a
> Bridge Registry which all works fine. In another location I am setting up
> another venue server. So far I have successfully installed the VenueServer,
> but my Bridge is not working. I run the Bridge server via a batch file with
> the name, location and the bridge registry path of the first Bridge
> Registry.
> The script that I am running is:
> Cd "C:\Program Files\AGTk-3\bin"
> C:\Python23\python.exe Bridge3.py
> --registryUrl=
> http://mybridgeregistryserver:8080/AGBridgeRegistry/peers.txt--name=MyBridgeName
> --location="My Location" --qbexec=./QuickBridge.exe
> All the Venue Clients are able to see my new bridge but all get an error
> message when they try and use it.
> "Connection to the bridge <name> failed. Please use a different bridge"
> The Bridge is being run on the same machine as the Venue server, and even
> the client on that same machine comes up with that same error.
> All the machine do not have connectivity to the internet.
> Any advice would be much appriciated.
> Boris
> *IMPORTANT:* This email remains the property of the Australian Defence
> Organisation and is subject to the jurisdiction of section 70 of the CRIMES
> ACT 1914. If you have received this email in error, you are requested to
> contact the sender and delete the email.
Beob Kyun Kim, PhD
e-Science Application Support Team,
e-Science Division,
Korea Institute of Science and Technology Information,
Daejeon, 305-806, South Korea
trugens at gmail.com, kyun at kisti.re.kr
Phone : +82-42-869-0782
Cell. +82-18-422-1584
Fax : +82-42-869-0782
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070509/27bae463/attachment.htm>
