[AG-TECH] bridge not in central registry
    Nicolas Bertrand
    nsb at ceh.ac.uk
    Fri Mar 30 06:40:13 CDT 2007
hello,
Apply the attached patched registry client to C:\Python23\Lib\site-packages\AccessGrid3\AccessGrid\Registry
That provides a workaround to the current limitations of having only 10 bridges listed.
Nic
>>> Kaizaad Bilimorya <kaizaad at sharcnet.ca> 03/30 2:44 am >>>
Hello,
We are running a bridge server that seems to drop out from the central
registry http://www.accessgrid.org/registry/peers.txt
Physically, the bridge doesn't seem to loose network connectivity, but
when a client starts up and gets the list of bridges, sometimes our bridge
is not there. After waiting a few minutes and then restarting the client,
the bridge shows up in the list:
Bridge	 Host             Port  Type        Status  Distance PortRange
SHARCNET agbs.sharcnet.ca 20000 QuickBridge Enabled 0.0160   50000-50200
I can actually just run the "RegistryClient.py" command (from the bridge
itself) and sometimes I see it listed but then on the next run it is gone.
name: SHARCNET  host: agbs.sharcnet.ca  port: 20000  dist:0.0015721321106
name: UofC  host: bullet.uchicago.edu  port: 20200  dist:0.0685670375824
name: Argonne  host: milton.mcs.anl.gov  port: 8030  dist:0.0720429420471
name: WestGrid  host: venueserver2.westgrid.ca  port: 20000  dist:0.172122955322
name: NIEeS  host: agiraffe.niees.group.cam.ac.uk  port: 29999  dist:0.353329181671
name: AGSC  host: sam.ag.manchester.ac.uk  port: 1992  dist:0.359209060669
name: onlyfinland  host: vy216.ucs.fi  port: 20000  dist:0.452105998993
name: APAG  host: vv3.ap-accessgrid.org  port: 20000  dist:0.751379966736
name: JCU  host: hpc-external.jcu.edu.au  port: 20000  dist:0.772580862045
name: Sheridan  host: oa-ag3-venue.sheridanc.on.ca  port: 20000  dist:8.37
I think it is dropping out of the registry because I would expect it to be
first in the list since it is the closest. Even when I increase the
"LookupBridge(self, maxToReturn=20):" it still is not listed some of the
time.
Any insight would be helpful
thanks
-k
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070330/ec08cc1d/attachment.diff>
