[AG-TECH] Extended video services with systems and venue server on the same subnet.
Jimmy Miklavcic
jimmy.miklavcic at utah.edu
Tue Mar 27 11:25:24 CDT 2007
I've been trying to use the extended video services but I think I found
a scenario where it doesn't' work. When I connect to the Argonne lobby,
there are several DVTS feeds there and I can connect and see all of them
and others can see my stream. But, when the venue server is on the same
subnet as my AG systems, I can not make a connection between two
machines, one with the extended producer and the other with the extended
consumer. Also others from outside can not connect with the dvts streams
either and I can not see their streams. It appears that a multicast path
is not established if both the venue server and my AG systems are on the
same subnet.
Any ideas?
Jimmy
Jimmy Miklavcic
Multimedia Specialist
Jimmy.Miklavcic at utah.edu <mailto:Jimmy.Miklavcic at utah.edu>
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.anotherlanguage.org <http://www.anotherlanguage.org/>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070327/c6b61bf9/attachment.htm>
