[AG-TECH] Intel HD audio
    Jeremy Mann
    jeremymann at gmail.com
    Tue Mar 27 09:07:32 CDT 2007
Thanks for the reply Doug. I got it to work by upgrading ALSA to
1.0.13 and loading the snd-pcm-oss module. Now we just need to select
the OSS: device in RAT for the audio to work.
On 3/26/07, Douglas Kosovic <douglask at itee.uq.edu.au> wrote:
> Hi Jeremy,
> > Anybody having trouble with the Intel HD integrated audio system using
> > Linux? I have one machine I'm desperately trying to get to work and its
> > RAT doesn't recognize the card. I've recompiled rat from CVS and also
> > upgraded ALSA to 1.0.13. When I start RAT and set the device to ALSA: 0
> > Intel HD I get:
> > to open device for playback
> > to open device for capture
> > Failed to set mixer levels
> > Since this is a common onboard audio system now, I'm hoping somebody else
> > has fixed this issue.
> Do you have any sound?  The default ALSA config often won't detect the
> correct intel HD audio model, which is often the case why sound doesn't
> work, see the docs that come with the ALSA source code for the appropriate
> snd-hda-intel kernel module argument.
> Try using the ALSA OSS compatibility layer, by selecting OSS in the rat
> audio configuration dialog box. On a Dell Optiplex 745, the onboard Intel HD
> audio seems to work with OSS compatibility.
> Doug
Jeremy Mann
jeremy at biochem.uthscsa.edu
University of Texas Health Science Center
Bioinformatics Core Facility
http://www.bioinformatics.uthscsa.edu
Phone: (210) 567-2672
