[AG-TECH] OSX install - is this the problem?
    John Toenjes UIUC
    jtoenjes at uiuc.edu
    Wed Mar 14 10:41:38 CDT 2007
Following up on my earlier email regarding difficulties installing
wxPython2.6-osx-unicode on my Powerbook G4...
The installer log shows this:
> Mar 14 10:30:32 jts-powerbook : run postflight script for
> wxPython2.6-osx-unicode-panther
> Mar 14 10:30:32 jts-powerbook : postflight[471]: /usr/bin/python2.3: can't
> open file
> '//System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/compi
> leall.py'
> Mar 14 10:30:32 jts-powerbook : Install failed: The following install step
> failed: run postflight script for wxPython2.6-osx-unicode-panther
I looked in
There is a file named compileall.pyo' but not one named compileall.py'
Could this be the problem? And if I copy compileall.pyo' and rename it to
compileall.py' do you think the installer will work?
Thanks.
John
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070314/cd914e23/attachment.htm>
