[AG-TECH] Sony EVI-HD1 camera
    gurcharan khanna
    gskpop at cis.rit.edu
    Sat Mar 10 00:01:56 CST 2007
Chris,
Another user-oriented issue is: if I have to choose among all possible
streams, how do I choose?
Before I run out of bandwidth, I normally choose based on content. Some
streams are redundant,
some are empty rooms, etc. In order to choose, I need to know/see what
it is I'm choosing. So,
ideally, I would be able to see thumbnails/low res versions of streams
so I could decide whether
or not I want to connect to them. I do this now with normal vic,
although all the bits from all the
streams are always hitting my network. With the limited bandwidth
demands of current vic streams
this is not a problem. But with HD streams, choosing only some streams
becomes more critical.
-gurcharan
Christoph Willing wrote:
> On 10/03/2007, at 4:55 AM, Bruce Curtis wrote:
>> On Mar 9, 2007, at 8:55 AM, gurcharan khanna wrote:
>>> All,
>>> I think sending all stream types is a great idea, so the receiver
>>> can choose the resolutions
>>> needed.
>>> A related issue is bandwidth limitations. If I choose to receive 261
>>> instead of HD for that
>>> reason, then I may not be able to tolerate all those bits on my
>>> network. So, then the issue
>>> becomes, how do I tell the source not to even send me the HD stream
>>> for instance but only
>>> the 261 streams? If the HD and 261 are two separate modules, then
>>> that would work. If they
>>> somehow are all integrated, maybe then that becomes a problem?
>>> -gurcharan
>>   Two ways to allow the receiver to choose between the streams would
>> be to
>>     1. Send the streams in separate multicast groups.
>>     2. Use Source Specific Multicast (SSM) and source the streams
>> from two different unicast source IP numbers.
> Gurcharan,
> Our current plan is to use the first of these methods that Bruce
> mentions. A twist on the AG toolkit's built in dynamic address
> allocation mechanism for new stream types makes this possible. Each
> new DV or HDV Producer is allocated a new multicast address. Any new
> DV or HDV Consumer is given a list of streams to choose from _before_
> subscribing to any of them.
> That means that for DV & HDV, there'll be a separate vic instance for
> each video source being viewed (as distinct to the default H261 video
> services which show all available video sources for a venue in the
> same vic instance). This is all sort of working now, but there is a
> problem with VenueClients up to v3.0.2 not being updated with new
> stream information after initially entering a venue; that will be
> fixed for AG 3.1.
> chris
>>>> On 09/03/2007, at 3:49 AM, John I Quebedeaux Jr wrote:
>>>>> Someone asked me about this camera for HD use on the AG:
>>>>> http://www.picturephone.com/products/sony_evi_hd1.htm
>>>>> Anyone have any experience with it? I'm wondering if it was used,
>>>>> how to best "capture" it into a system for use on the AG...
>>>>> interest in using HD is high here. I'm more concerned about
>>>>> logistical issues with high resolution images on displays that
>>>>> don't have that much "resolution" space - particularly if several
>>>>> sites are involved.
>>>> John,
>>>> With regard to screen space logistics, we've developed a version of
>>>> vic that does DV and HDV - full details and perhaps a demo at the
>>>> forthcoming AG Retreat. One of the changes is the ability to resize
>>>> the video window(s) to any size you like. Thus you could accomodate
>>>> several streams at smaller than true HD size when display space
>>>> becomes tight.
>>>> BTW, I think that when DV, HDV, HD are all more common in the AG,
>>>> best practice will be to always send those formats as duplicates of
>>>> standard H261 streams so that other sites can choose to view their
>>>> own preferred mix of H261 and higher resolution formats (somewhat
>>>> avoiding the screen real estate problem you raised, not to mention
>>>> bandwidth issues). The cameras we've been testing with have a
>>>> number of simultaneous outputs available so its trivial to send
>>>> both DV/HDV and H261 at the same time.
>>>> chris
>>>> Christoph Willing                       +61 7 3365 8350
>>>> QCIF Access Grid Manager
>>>> University of Queensland
>>> Gurcharan S. Khanna, Ph.D.
>>> Director of Research Computing
>>> Office of the Vice President for Research
>>> Director, Interactive Collaboration Environments Laboratory,
>>> Center for the Advancing the Study of Cyberinfrastructure
>>> Rochester Institute of Technology
>>> 1 Lomb Memorial Drive
>>> Rochester, New York 14623-5603
>>> Phone: 585-475-7504  ~  Cell: 585-355-1603
>>> Email: gurcharan.khanna at rit.edu
>>> Http:  www.rit.edu/~gskpop
>> Bruce Curtis                         bruce.curtis at ndsu.edu
>> Certified NetAnalyst II                701-231-8527
>> North Dakota State University
http://www.rit.edu/~gskpop
