[AG-TECH] Problem with run BridgeServer in AG3.0.2
Eddy Diaz
edd-diaz at uniandes.edu.co
Thu Mar 1 18:35:45 CST 2007
Christoph,
I tried with:
C:\Archivos de programa\AGTk-3\bin>Bridge3.py --name="Prueba"
--location="Bogota, Colombia" --qbexec="C:\Archivos de
programa\AGTk-3\bin\QuickBridge.exe"
Traceback (most recent call last):
File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 187, in ?
main()
File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 182, in main
bridgeServer = QuickBridgeServer(name=options.name, location=options.locatio
n, listenPort=options.listenPort, qbexec=options.qbexec,
portRange=options.portRange, registryUrl=options.registryUrl)
File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 47, in __init__
self._RegisterWithRegistry()
File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 84, in
self.validSecs =
self.registryClient.RegisterBridge(self.bridgeDescription)
File
"C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryCl
ient.py", line 56, in RegisterBridge
return self.serverProxy.RegisterBridge(registeredServerInfo)
AttributeError: 'NoneType' object has no attribute 'RegisterBridge'
Then I tried with my own registry
C:\Python23\Lib\site-packages\AccessGrid3\AccessGrid\Registry>RegistryPeer.p
y --port=8030
--peerListUrl=http://ag-mox.uniandes.edu.co/accessgrid/peers.txt
File
"C:\Python23\Lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryPeer.
py", line 9, in ?
from AccessGrid.AGXMLRPCServer import AsyncAGXMLRPCServer
ImportError: No module named AccessGrid.AGXMLRPCServer
I fix the problem adding at the beginning of the file RegistryPeer.py this
lines
import agversion
agversion.select(3)
Then I ran the registry again
y --port=8030
File
py", line 185, in ?
r = RegistryPeer(peerListUrl=options.peerListUrl, port=options.port)
File
py", line 150, in __init__
RegistryBase.__init__(self, port, peerListUrl)
File
py", line 44, in __init__
self._readPeerList(url=self.peerListUrl)
File
py", line 59, in _readPeerList
raise Exception ("Error: this peer " + localPeerName + " is not listed
in the master list. The current registry requires all peers to know about
each other.")
Exception: Error: this peer aquel:8030 is not listed in the master list.
The current registry requires all peers to know about each other.
Thanks.
Eddy Johel Diaz Murcia edd-diaz at uniandes.edu.co
Estudiante de Maestría Murcia en Ingeniería de Sistemas y computación
Asistente graduado del Grupo IMAGINE Universidad de los Andes
Carrera 1 N° 18A-10 Bloque W, Bogotá, Colombia
Laboratorio de Informática Gráfica Teléfono: +57(1) 339 4949 Extensión 3462
-----Mensaje original-----
De: Christoph Willing [mailto:willing at vislab.uq.edu.au]
Enviado el: Jueves, 01 de Marzo de 2007 06:43 p.m.
Para: Eddy Diaz
CC: ag-tech at mcs.anl.gov
Asunto: Re: [AG-TECH] Problem with run BridgeServer in AG3.0.2
On 02/03/2007, at 12:35 PM, Eddy Diaz wrote:
> Hi, now I try in Windows XP with several options, and I try with my
> own
> registry too.
> I have the same Problem.
Eddy,
Try quoting the name, same as you did for location i.e. --
name="Prueba" ....
Also, I just noticed that you sometimes used --registryUrl=https://
aquel.uniandes.edu.co:8000/Venues/default, which is incorrect - you
need something like --registryUrl=http://ag-mox.uniandes.edu.co/
accessgrid/peers.txt (as you previously tried).
So, I think what you need for Linux is:
Bridge --name="Prueba" --registryUrl=http://ag-
mox.uniandes.edu.co/accessgrid/peers.txt --location="Bogota, Columbia"
where the peers.txt file should contain the name:port of the the
machine running your registry; at the moment, that appears to be
aquel.uniandes.edu.co:8030 - that machine needs to be running
RegistryPeer.py with --port=8030 (thats the default anyway) and --
(whatever you specified for --registryUrl for Bridge)
chris
> C:\Archivos de programa\AGTk-3\bin>Bridge3.py --name=Prueba
> --location="Bogota,
> Colombia" --qbexec="C:\Archivos de programa\AGTk-3\bin
> \QuickBridge.exe"
> main()
> main
> __init__
> self.validSecs = self.registryClient.RegisterBridge
> File
> \RegistryClien
> --registryUrl=http://ag-mox.uniandes.edu.co/accessgrid/peers.txt
> main()
> main
> location=options.location, listenPort=options.listenPort,
> qbexec=options.qbexec, portRange=options.portRange,
> __init__
> File
> "C:\Python23\lib\sitepackages\AccessGrid3\AccessGrid\Registry
> \RegistryCl
> Extensión 3462
> De: Eddy Diaz [mailto:eddy at uniandes.edu.co]
> Enviado el: Martes, 20 de Febrero de 2007 09:05 a.m.
> Para: Christoph Willing
> CC: Eddy Diaz; ag-tech at mcs.anl.gov
> Hi Christoph
> I tried with this
> [eddy at aquel ~]$
> Bridge --name=Prueba --url=https://aquel.uniandes.edu.co:8000/
> Venues/default
> --location="Bogota,
> Colombia"
> usage: Bridge [options]
> Bridge: error: no such option: --url
> Then I tried with this
> [eddy at aquel ~]$
> --registryUrl=https://aquel.uniandes.edu.co:8000/Venues/default
> --location="Bogota,
> Colombia"
> File "/usr/bin/Bridge", line 187, in ?
> main()
> File "/usr/bin/Bridge", line 182, in main
> File "/usr/bin/Bridge", line 47, in __init__
> File "/usr/bin/Bridge", line 84, in _RegisterWithRegistry
> self.validSecs =
> File
> "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/Registry/
> RegistryCl
> ient.py",
> line 108, in RegisterBridge
> The options provided by my bridge are:
> [eddy at aquel ~]$ Bridge
> Error: No name specified
> options:
> -h, --help show this help message and exit
> -p LISTENPORT, --listenPort=LISTENPORT
> Port to listen on.
> -u REGISTRYURL, --registryUrl=REGISTRYURL
> Url to the registry. Bridge will register
> with it.
> -r PORTRANGE, --portRange=PORTRANGE
> Minimum and maximum port, space-separated.
> -q QBEXEC, --qbexec=QBEXEC
> Location of QuickBridge executable.
> -n NAME, --name=NAME Name.
> -l LOCATION, --location=LOCATION
> Location.
> El Monday 19 February 2007 20:02:25 Christoph Willing escribió:
>> On 20/02/2007, at 2:51 PM, Eddy Diaz wrote:
>>> I'm trying to run a bridge in Fedora core 6 and AccessGrid 3.0.2
>>> but an error appears.
>>> $ Bridge --name=Prueba --location=https://aquel.uniandes.edu.co:
>>> 8000/Venues/default
>> Eddy,
>> The --location option is for a descriptive string, not the server
>> url. You should run with something like:
> --url=https://aquel.uniandes.edu.co:8000/Venues/
>> default --location="Bogota, Colombia"
>> chris
>>> main()
>>> File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/
>>> Registry/RegistryClient.py", line 107, in RegisterBridge
>>> Eddy Johel Diaz edd-diaz at uniandes.edu.co
>>> computación
>>> Extensión 3462
>> Christoph Willing +61 7 3365 8350
>> QCIF Access Grid Manager
>> University of Queensland
> Eddy Johel Diaz
> Estudiante de Maestría en Ingeniería de Sistemas y computación
> Carrera 1 Nro 18A-10 Bloque W, Bogotá, Colombia
