[AG-TECH] Problem with run BridgeServer in AG3.0.2
    Christoph Willing
    willing at vislab.uq.edu.au
    Thu Mar  1 17:42:51 CST 2007
On 02/03/2007, at 12:35 PM, Eddy Diaz wrote:
> Hi, now I try in Windows XP with several options, and I try with my
> own
> registry too.
>  I have the same Problem.
Eddy,
Try quoting the name, same as you did for location i.e. --
name="Prueba" ....
Also, I just noticed that you sometimes used --registryUrl=https://
aquel.uniandes.edu.co:8000/Venues/default, which is incorrect - you
need something like --registryUrl=http://ag-mox.uniandes.edu.co/
accessgrid/peers.txt (as you previously tried).
So, I think what you need for Linux is:
     Bridge --name="Prueba" --registryUrl=http://ag-
mox.uniandes.edu.co/accessgrid/peers.txt --location="Bogota, Columbia"
where the peers.txt file should contain the name:port of the the
machine running your registry; at the moment, that appears to be
aquel.uniandes.edu.co:8030 - that machine needs to be running
RegistryPeer.py with --port=8030 (thats the default anyway) and --
peerListUrl=http://ag-mox.uniandes.edu.co/accessgrid/peers.txt
(whatever you specified for --registryUrl for Bridge)
chris
> C:\Archivos de programa\AGTk-3\bin>Bridge3.py --name=Prueba
> --location="Bogota,
> Colombia" --qbexec="C:\Archivos de programa\AGTk-3\bin
> \QuickBridge.exe"
> Traceback (most recent call last):
> File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 187, in ?
>     main()
> File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 182, in
> main
> bridgeServer = QuickBridgeServer(name=options.name,
> location=options.locatio
> n, listenPort=options.listenPort, qbexec=options.qbexec,
> portRange=options.portRange, registryUrl=options.registryUrl)
> File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 47, in
> __init__
> self._RegisterWithRegistry()
> File "C:\Archivos de programa\AGTk-3\bin\Bridge3.py", line 84, in
> self.validSecs = self.registryClient.RegisterBridge
> (self.bridgeDescription)
> File
> "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Registry
> \RegistryClien
> t.py", line 56, in RegisterBridge
> return self.serverProxy.RegisterBridge(registeredServerInfo)
> AttributeError: 'NoneType' object has no attribute 'RegisterBridge'
> --registryUrl=http://ag-mox.uniandes.edu.co/accessgrid/peers.txt
> --location="Bogota, Colombia" --qbexec="C:\Archivos de
> programa\AGTk-3\bin\QuickBridge.exe"
>     main()
> main
> location=options.location, listenPort=options.listenPort,
> qbexec=options.qbexec, portRange=options.portRange,
> __init__
>   File
> "C:\Python23\lib\sitepackages\AccessGrid3\AccessGrid\Registry
> \RegistryCl
> ient.py", line 56, in RegisterBridge
> Eddy Johel Diaz Murcia edd-diaz at uniandes.edu.co
> Estudiante de Maestría Murcia en Ingeniería de Sistemas y computación
> Asistente graduado del Grupo IMAGINE Universidad de los Andes
> Carrera 1 N° 18A-10 Bloque W, Bogotá, Colombia
> Laboratorio de Informática Gráfica Teléfono: +57(1) 339 4949
> Extensión 3462
> -----Mensaje original-----
> De: Eddy Diaz [mailto:eddy at uniandes.edu.co]
> Enviado el: Martes, 20 de Febrero de 2007 09:05 a.m.
> Para: Christoph Willing
> CC: Eddy Diaz; ag-tech at mcs.anl.gov
> Asunto: Re: [AG-TECH] Problem with run BridgeServer in AG3.0.2
> Hi Christoph
> I tried with this
> [eddy at aquel ~]$
> Bridge --name=Prueba --url=https://aquel.uniandes.edu.co:8000/
> Venues/default
> --location="Bogota,
> Colombia"
> usage: Bridge [options]
> Bridge: error: no such option: --url
> Then I tried with this
> [eddy at aquel ~]$
> --registryUrl=https://aquel.uniandes.edu.co:8000/Venues/default
> --location="Bogota,
> Colombia"
>   File "/usr/bin/Bridge", line 187, in ?
>     main()
>   File "/usr/bin/Bridge", line 182, in main
>   File "/usr/bin/Bridge", line 47, in __init__
>   File "/usr/bin/Bridge", line 84, in _RegisterWithRegistry
>     self.validSecs =
> self.registryClient.RegisterBridge(self.bridgeDescription)
> File
> "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/Registry/
> RegistryCl
> ient.py",
> line 108, in RegisterBridge
> The options provided by my bridge are:
> [eddy at aquel ~]$ Bridge
> Error: No name specified
> options:
>   -h, --help            show this help message and exit
>   -p LISTENPORT, --listenPort=LISTENPORT
>                         Port to listen on.
>   -u REGISTRYURL, --registryUrl=REGISTRYURL
>                         Url to the registry.  Bridge will register
> with it.
>   -r PORTRANGE, --portRange=PORTRANGE
>                         Minimum and maximum port, space-separated.
>   -q QBEXEC, --qbexec=QBEXEC
>                         Location of QuickBridge executable.
>   -n NAME, --name=NAME  Name.
>   -l LOCATION, --location=LOCATION
>                         Location.
> El Monday 19 February 2007 20:02:25 Christoph Willing escribió:
>> On 20/02/2007, at 2:51 PM, Eddy Diaz wrote:
>>> I'm trying to run a bridge in Fedora core 6 and AccessGrid 3.0.2
>>> but an error appears.
>>> $ Bridge --name=Prueba --location=https://aquel.uniandes.edu.co:
>>> 8000/Venues/default
>> Eddy,
>> The --location option is for a descriptive string, not the server
>> url. You should run with something like:
> --url=https://aquel.uniandes.edu.co:8000/Venues/
>> default --location="Bogota, Colombia"
>> chris
>>> main()
>>> File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/
>>> Registry/RegistryClient.py", line 107, in RegisterBridge
>>> Eddy Johel Diaz edd-diaz at uniandes.edu.co
>>> computación
>>> Extensión 3462
>> Christoph Willing                       +61 7 3365 8350
>> QCIF Access Grid Manager
>> University of Queensland
> Eddy Johel Diaz
> Estudiante de Maestría en Ingeniería de Sistemas y computación
> Carrera 1 Nro 18A-10 Bloque W, Bogotá, Colombia
> Teléfono: +57(1) 339 4949 Extensión 3462
