[Sumover-tech] RE: [AG-TECH] Patched vic for incoming port?
Piers O'Hanlon
p.ohanlon at cs.ucl.ac.uk
Wed Jun 20 09:12:31 CDT 2007
Hi folks,
I've committed the patch for same port operation ( Try to match source
port to dest port before using ephemeral source port) to the SUMOVER
vic - it now also includes the Tcl noMulticastBind resource to allow
for not joining the multicast group - so vic would only send video and
not receive - useful in low bandwidth situations.
Piers.
On 19/06/07, Douglas Kosovic <douglask at itee.uq.edu.au> wrote:
> Hi Jeremy,
> > Is there a patch or patched version of VIC to cope with the random
> > incoming port issue that was discussed at the Retreat? I've tried
> > SUMOVERs and the one from VISLAB. I think I remember reading a thread
> > that this was fixed in a Windows version of VIC.
> I think you are referring to the "Try to match source port to dest port
> before using ephemeral source port" fix which can be seen in the logs for
> net-ip.cpp here:
> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/ag-media/vic/net/
> Similar modifications to net-ip.cpp in SUMOVER SVN don't appear to be there:
> http://mediatools.cs.ucl.ac.uk/nets/mmedia/browser/vic/branches/mpeg4/net
> The UQ Vislab DV/HDV vic should have those modifications as it's source was
> based on AG vic, if it's some other vic from UQ Vislab, it's probably a
> recent UCL vic from the SUMOVER SVN.
> Cheers,
> Doug
> Sumover-tech mailing list
> Sumover-tech at cs.ucl.ac.uk
> http://oakham.cs.ucl.ac.uk/mailman/listinfo/sumover-tech
