[AG-TECH] Access Grid 3.0.2-node setup wizard crashing
Thomas D. Uram
turam at mcs.anl.gov
Wed Jun 13 14:25:42 CDT 2007
Hi Sandeep:
Try looking in the NodeSetupWizard.log file, in
C:\Documents and Settings\<you>\Application Data\AccessGrid3\Logs.
If you don't see any evidence of the problem there, you can send the log
file along so we can look at it
to determine the problem.
Another thing you could do is try running the NodeSetupWizard.py from
the command line, to see
if errors are printed to the shell.
Tom
On 6/13/07 8:52 AM, Sandeep Pandanaboyana wrote:
> Hi,
> I recently installed Access Grid 3.0.2 on two machines running windows xp.The machines are
> 1.display
> 2.portadisplay
> We are using the machine display to capture the video and portadisplay for audio purposes. Both the machines are running Access grid 2.4 and Access grid 3.0.2 versions.
> Now when I ran the service manager on "display" and opened the node setup wizard on "portadisplay", the node setup wizard starts and crashes up. I encountered the same problem when I ran service manager on "portadisplay" and tried to open the node setup wizard on "display".
> The Access grid 2.4 version, present on both the machines, however is working fine and I am able to open the node setup wizard and it doesn't crash. I tried doing a clean install of Access Grid 3, but the problem still persists.
> Did anybody encounter the same problem and does anyone have any suggestions?
> Thanks in Advance
> CCS
> University Of kentucky
> 1.display
> 2.portadisplay
> Thanks in Advance
> Sandeep Pan
