[AG-TECH] multimachine node problem...
Porfirio Gaona
pgg at ixtli.unam.mx
Tue Jun 12 12:31:11 CDT 2007
Hi Doug,
Thanks for your answer. No, my display PC is on Windows XP for 64
bits. This machine has this OS because we're integrating Virtual
Reality project in 3 proyectors using blending zone. Audio and Video
PCs have Fedora and have /etc/host file with all data.
I tested in two PCs with XP 32 bits and none problem.
Thanks in advance
Porfirio Gaona
UNAM Mexico
On Jun 12, 2007, at 6:34 AM, Douglas Kosovic wrote:
> Hi Porfirio,
>> I changed my display machine. My new machine is an Opteron 64
>> bits, but
>> I have a problem when I've tried to communicate with my audio and
>> video
>> machine. When I try to configurate my Access Grid Node Management,
>> there's no communication with audio and video PC's.
> I assume your display PC is running x86-64 linux. If it's Fedora
> and you
> are not using DHCP, you will need to modify /etc/hosts, see:
> http://www.accessgrid.org/node/778
> Cheers,
> Doug
