[AG-TECH] FC7 Issues
Todd Zimmerman
toddz at sfu.ca
Tue Jun 5 12:29:56 CDT 2007
Not sure if the FC7 packages are 'complete' and fully supported yet; however I have got AG3 running
on FC7 with a couple of changes.
First off, for some reason doing a 'yum install AccessGrid' failed because of a python-ZSI missing
dependency. The rpm is in the repository, so I just downloaded/installed it manually:
http://www.vislab.uq.edu.au/accessgrid3/fedora/7/i386/python-ZSI-2.0-2.20070427svn.fc7.noarch.rpm
The second issue was failure to contact the bridge registry. The logs showed:
06/05/2007 09:41:15 AM -1208486208 RegistryClient RegistryClient.py:98 ERROR Failed to connect
to registry vv3.mcs.anl.gov:8030
Traceback (most recent call last):
File "/usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/Registry/RegistryClient.py", line
93, in _connectToRegistry
if self.PingRegistryPeer(tmpServerProxy) > -1:
110, in PingRegistryPeer
startTime = serverProxy.Ping(time.time())
File "/usr/lib/python2.5/xmlrpclib.py", line 1147, in __call__
return self.__send(self.__name, args)
File "/usr/lib/python2.5/xmlrpclib.py", line 1437, in __request
verbose=self.__verbose
File "/usr/lib/python2.5/xmlrpclib.py", line 1201, in request
return self._parse_response(h.getfile(), sock)
File "/usr/lib/python2.5/xmlrpclib.py", line 1324, in _parse_response
p, u = self.getparser()
File "/usr/lib/python2.5/xmlrpclib.py", line 1210, in getparser
return getparser(use_datetime=self._use_datetime)
AttributeError: TimeoutTransport instance has no attribute '_use_datetime'
I solved this issue by adding a _use_datetime attribute to the Transport class in
/usr/lib/python2.5/xmlrpclib.py (~ line 1160)
_use_datetime = False
Not sure if these are known issues - but those changes got me rolling.
Cheers,
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
