[AG-TECH] Re: [AG-DEV] AG3.1 Vic on OSX Issues
    Thomas D. Uram
    turam at mcs.anl.gov
    Fri Jul 27 15:31:28 CDT 2007
Todd:
An unrelated bug has been filed against vic on OSX:
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1673
but as part of it, a new executable has been built with some new
network-related code.  It would be great if you could run some tests
with this newer executable.
Tom
On 7/27/07 3:18 PM, Todd Zimmerman wrote:
> Wondering if anyone else is experiencing problems with the OSX vic build for AG3.1. On our setup, we
> have a OSX box doing the video consuming - and a linux box doing the vid capture.  The linux box can
> see all of the incoming (muted) sources, however the OSX box shows no incoming video at all.
> I've tcpdumped on both the bridge machine and the local OSX box and there are definitely incoming
> packets from the bridge; however vic shows no video.  The fact that there are packets arriving seems
> to rule out firewall - so I'm left with vic as the problem.
> I've tried using vic as a VideoService on the OSX box and sending out via iSight camera also.  Vic
> does show the iSight - but still no incoming video.  I have got the video feeds to appear once;
> however I can't replicate it.  I believe it started in some combination of starting a second vic
> from the command line and sending a feed out to the bridge... but like I said, I can't replicate it.
> I'll file a bug report but wanted to make sure it wasn't a local issue first.
> Cheers,
> Todd
