[AG-TECH] 3.1.0b1 mac audio
Fred Dech
fdech at uchicago.edu
Thu Jul 26 11:22:33 CDT 2007
that's interesting.
i just uninstalled/reinstalled. slightly different look on this RAT than
the version i was running. this one has a different background color...
pail, instead of gray-ish. same intel RAT version; 4.4.00.
i still have the same half-second delay in RAT, though.
maybe it's because i am using a line-in/speaker-out -> USB converter for
my headset. but i can't test line-in directly. my line-in refuses to pick
up the mic input today...
On Thu, Jul 26, 2007 at 02:36PM, Piers O'Hanlon wrote:
> >the fact that you do not hear a delay with the native intel build is
> >promising. also, thanks for the Rosetta ppc explanation that elucidates
> >what has been a mystery to me for some time.
> >i'm going to take a closer look at my system, probably do a more thorough
> >uninstall and test some more with a clean install of 3.1b1.
> Sounds good. One easy way to check is to run the Activity Monitor and
> go to the View menu and add the 'Kind' column to the Activity
> Monitor's process viewer - that should then show you if RAT (or
> anything else) is running as Native Intel or PowerPC.
> Piers.
> >thanks.
> >-fred
