[AG-TECH] Audio Reflector room
Christoph Willing
willing at vislab.uq.edu.au
Tue Jul 17 07:44:29 CDT 2007
On 17/07/2007, at 9:03 PM, Samuel Gundry wrote:
> Hi Chris and Markus,
> Thanks for the responses. I cannot see the two entries of my own
> node or the "APAG AudioReflector" node in Rat itself, when in the
> Audio Reflector venue.
> I turned off the firewall (I know, silly) and installed the audio
> reflector controller app and received the following error:
>> 17/07/2007 20:53:51 : Started
>> 17/07/2007 20:54:12 : Failed contacting server (socket.error:
>> (10060, 'Operation timted out'))
> I adjusted the reflection delay and pressed apply but it still
> timed out... It certainly seems like a firewall error of sorts, any
> ideas? Might be my router, do I need to open a specific port?
Sam,
There are 2 issues involved concerning the controller application.
Firstly, the existing controller app was written for AG2 and,
secondly, the reflector server location (which is hard coded into the
app) is out of date.
I've created an updated controller shared application for AG3 and put
it in the Data section of the Audio Reflector venue of the vv3.ap-
accessgrid.org venue server. I've just tested it from home (no
multicast) and it works fine although there are no built-in sounds
available on the server.
> The bars in Rat are moving up and down as I speak into the
> microphone, but there is no bars in the listen section. Does this
> mean that my microphone input is local for Rat, but the server
> cannot be contacted to listen to the sound?
It looks that way. Have you tried connecting via a bridge? That may
work around a multicast problem at your end.
chris
> Markus Buchhorn wrote:
>> You should also run the audio reflector controller application
>> (which is normally stored in the venue data - I can't check or
>> test right now). That has the option to play back standard sounds
>> stored in the reflector, so you can test inbound paths separately
>> from outbound.
>> Cheers,
>> Markus
>> At 10:35 AM 17/07/2007, Christoph Willing wrote:
>>> On 16/07/2007, at 8:26 PM, Samuel Gundry wrote:
>>>> Hi,
>>>> The audio reflector and the second participant of me don't
>>>> appear when I visit the "Audio Reflector" venue (for AG 3.0.2),
>>>> as per the instructions here: <http://www.accessgrid.org/node/
>>>> 354>http://www.accessgrid.org/node/354
>>>> Does the room work for anyone else? Or is the room broken?
>>> I used it successfully yesterday when testing a laptop node in
>>> the Library and again just now from our lab node.
>>>> I'm using this address: <https://vv3.ap-accessgrid.org:8000/
>>>> Venues/00000103104e90bd0081004e009d00a8bbc>https://vv3.ap-
>>>> accessgrid.org:8000/Venues/00000103104e90bd0081004e009d00a8bbc
>>>> I want to test out my sound (obviously), the bars in RAT are
>>>> moving but I don't have any way to test the sound...
>>> Perhaps your signal isn't reaching the reflector. When you're in
>>> that venue, you should see the "APAG AudioReflector" entry in rat
>>> itself. You should also see 2 entries for your own node. If you
>>> don't see all those entries then your traffic isn't being seen
>>> (and audio reflection can't work) - therefore check your
>>> firewalls, multicast etc.
>>> chris
>>> Christoph Willing +61 7 3365 8350
>>> QCIF Access Grid Manager
>>> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070717/58bde282/attachment.htm>
