[AG-TECH] Limit for number of video devices?
    Thomas D. Uram
    turam at mcs.anl.gov
    Tue Jan 30 11:21:18 CST 2007
Addressing the technical limitation:  Yes, vic is hardcoded to
scan for ten devices.  I think vic should be able to discover
all the devices, so I'm copying the UCL media tools
developers, who will likely be the ones to address this.
I agree with Derek that you would likely overwhelm typical
AG participants.  But I also think that you should have access
to all those capture devices, for a couple reasons:  (1) because
you should be able to access /any/ capture device on your
system; (2) because we shouldn't have hard-coded limits;
(3) because you should be able to do whatever interesting things
you like.
If you want to modify vic yourself and rebuild it, the hard-coding
is in vic/video/grabber-win32DS.h, in the global variable NUM_DEVS.
Tom
On 1/30/07 8:13 AM, Derek Piper wrote:
>     Apart from any technical limitations that may exist it should be
> pointed out that you should probably not have THAT many cameras as
> your site would be rather overwhelming to other AG participants. 2 or
> 3 cameras should suffice for most meetings.
>     Derek
> Almuth Barta wrote:
>> Hi,
>> I'm setting up a new machine as AGN Client (WindowsXP SP2). For Video
>> I have a Viewcast Osprey 440 Capture card with 4 Video inputs.
>> These videoinputs were shown as
>> Osprey-440 Video Device 1A
>> Osprey-440 Video Device 1B
>> Osprey-440 Video Device 1C
>> Osprey-440 Video Device 1D
>> So far, everything was ok.
>> After registering Simulstream, i got a list of 16 devices:
>> Osprey-440 Video Device 1A.1
>> Osprey-440 Video Device 1A.2
>> Osprey-440 Video Device 1A.3
>> Osprey-440 Video Device 1A.4
>> Osprey-440 Video Device 1B.1
>> Osprey-440 Video Device 1D.4.
>> These are shown in the Swiftcap Software, that came with the Osprey
>> card.
>> The AGN-client only shows the first 10 of these video devices, so I
>> get a list with only:
>> Osprey-440 Video Device 1B.3
>> Osprey-440 Video Device 1B.2
>> Osprey-440 Video Device 1B.4
>> Osprey-440 Video Device 1C.3
>> Osprey-440 Video Device 1C.2
>> Is there a limitation in the scan for video devices so that I cannot
>> see more than 10?
>> Any hints how I can increase this?
>> Thanks for any help.
>> Almuth
