[AG-TECH] Limit for number of video devices?
    John I Quebedeaux Jr
    johnq at lsu.edu
    Tue Jan 30 09:40:46 CST 2007
Almuth,
Simulstream is the Osprey's software for allowing multiple
applications to access the same stream. It  isn't usually needed for
AG use unless you're requiring that multiple applications are needing
access to the same stream. For example,  It could be useful if you
wanted to web-stream your outputs as well as have VIC transmit them.
If you look, you now have multiple copies of the same stream
available to you.... from each capture.
-John Q.
John I. Quebedeaux, Jr.; Louisiana State University
Computer Manager LBRN; 131 Life Sciences Bldg.
e-mail: johnq at lsu.edu; web: http://lbrn.lsu.edu
phone: 225-578-0062 / fax: 225-578-2597
On Jan 30, 2007, at 8:25 AM, Almuth Barta wrote:
> I don't want to use 16 cameras, of course.
> But I want to get the complete list to be able to choose the ones I
> need (i.e. those numbered 1A.1, 1B.1, 1C.1 and 1D.1)
> Almuth
> Derek Piper wrote:
>>     Apart from any technical limitations that may exist it should
>> be pointed out that you should probably not have THAT many cameras
>> as your site would be rather overwhelming to other AG
>> participants. 2 or 3 cameras should suffice for most meetings.
>>     Derek
>> Almuth Barta wrote:
>>> Hi,
>>> I'm setting up a new machine as AGN Client (WindowsXP SP2). For
>>> Video I have a Viewcast Osprey 440 Capture card with 4 Video inputs.
>>> These videoinputs were shown as
>>> Osprey-440 Video Device 1A
>>> Osprey-440 Video Device 1B
>>> Osprey-440 Video Device 1C
>>> Osprey-440 Video Device 1D
>>> So far, everything was ok.
>>> After registering Simulstream, i got a list of 16 devices:
>>> Osprey-440 Video Device 1A.1
>>> Osprey-440 Video Device 1A.2
>>> Osprey-440 Video Device 1A.3
>>> Osprey-440 Video Device 1A.4
>>> Osprey-440 Video Device 1B.1
>>> Osprey-440 Video Device 1D.4.
>>> These are shown in the Swiftcap Software, that came with the
>>> Osprey card.
>>> The AGN-client only shows the first 10 of these video devices, so
>>> I get a list with only:
>>> Osprey-440 Video Device 1B.3
>>> Osprey-440 Video Device 1B.2
>>> Osprey-440 Video Device 1B.4
>>> Osprey-440 Video Device 1C.3
>>> Osprey-440 Video Device 1C.2
>>> Is there a limitation in the scan for video devices so that I
>>> cannot see more than 10?
>>> Any hints how I can increase this?
>>> Thanks for any help.
>>> Almuth
> Almuth Barta
> Systemadministratorin
> Max-Planck-Institut für Gravitationsphysik / Albert-Einstein-Institut
> Am Mühlenberg 1,  14476 Potsdam-Golm
> Tel.: +49 (0)331 567 7304   Fax:  +49 (0)331 567 7298
> e-mail: almuth.barta at aei.mpg.de
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070130/19f8ddd6/attachment.htm>
