[AG-TECH] ag3 install/starting problems
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Jan 24 14:22:28 CST 2007
You could try this:
- open a command prompt
- cd c:\program files\agtk-3\bin
- venueclient3.py -d
If the venueclient is not starting, some indication of the problem
should print in the command window.
I'm very curious to hear what it is.
Tom
On 1/24/07 2:06 PM, Paul Mercer wrote:
> All
> I'm having a problem installing ag3 on a win xp box at a local high
> school.  The installation seems to go ok, installing all required
> packages but when I try and start the venue client nothing happens.
> Looking at the task manager-->processes  I see that pythonw.exe starts
> for a few seconds but then stops.  Logs are empty. I have seen this
> problem before but I installed using a non-admin account.  This time I
> was logged in as an admin.
> firewall is off
> I have uninstalled and downloaded packages again and reinstalled to no
> avail.
> Has anyone else see this problem or knows what is going on?
> thank  you
> Paul Mercer
> Arctic Region Supercomputing Center
> 907 450 8649
