[AG-TECH] AGTK3.0.2 on Red Hat Enterprise Version 4
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Jan 16 19:57:57 CST 2007
Todd Zimmerman wrote:
> Paul Bonnett wrote:
>> Does anyone have AG3 running on Red Hat Enterprise Version 4?
>> I want to install a venue server on it specifically, and don't have much
>> experience with Linux.
> Yes. WestGrid's main venueserver (AG2 currently) is running on RHEL4.
> It's been a nice stable venueserver for . It's been a long time since I
> did the install so I can't remember what issues I ran into; however I
> think the rpm's installed fine. If I remember correctly, the compatible
> rpms are Fedora Core 3 - but you may want to confirm with Doug Kosovic
> (the maintainer) on that.
The AG FC3 RPMs from here:
http://www.vislab.uq.edu.au/accessgrid3/fedora/3/
should work fine with RHEL 4 (except for wxMozilla, required only if you
want to have the SharedBrowser working), any missing depedencies can be
found in Fedora Extras 3:
http://download.fedora.redhat.com/pub/fedora/linux/extras/3/
The FC3 wxMozilla RPM doesn't work with RHEL 4 update 4 because seamonkey
has replaced the mozilla RPM. You could rebuild wxMozilla on RHEL4 by
downloading and rebuilding the FC5 wxMozilla SRPM which builds against
seamonkey,
http://www.vislab.uq.edu.au/accessgrid3/fedora/5/SRPMS/wxMozilla-0.5.7-0.1.20061218cvs.fc5.src.rpm ,
e.g:
rpmbuild --rebuild wxMozilla-0.5.7-0.1.20061218cvs.fc5.src.rpm
The upcoming AGTk 3.1 release won't work with RHEL4, because the
m2crypto-0.17 dependency requires a newer python and openssl than what ships
with RHEL4. The soon to be released RHEL5 won't have a problem as it is
based on FC6.
Doug
