[AG-TECH] AGService development problem
Thomas D. Uram
turam at mcs.anl.gov
Tue Jan 16 15:02:07 CST 2007
Hi Ismail:
If you're able to reproduce this problem reliably, I'd like to know how.
I suspected I might know how to trigger the problem, but have so far been
unable to. If it's a problem in current code, I'd like to get it fixed.
Tom
On 1/14/07 4:58 AM, Ismail Bhana wrote:
> Christoph Willing wrote:
>> On 14/01/2007, at 1:01 AM, Ismail Bhana wrote:
>>> I've been developing a set of node services called JMast
>>> (JMastConsumer and JMastProducer services) which basically provide a
>>> form of application sharing using streaming technologies. However,
>>> whilst I can get the software to boot from AG 3.0.2 with parameters
>>> passed correctly I'm having a problem where I'm being passed the
>>> same multicast address/port as the vic tool which causes vic to
>>> crash. If I change the Capabilities type (say, from "JMAST" to
>>> "jmast1") a different address to vic is assigned in the first
>>> instance of execution but the next time I run the software its back
>>> to giving me the same address/port as vic and I can't really work
>>> out why.
>> Ismail,
>> I've seen this too in another service we've been developing and would
>> be interested in knowing the cause.
>> One thing I found which has lessened the problem somewhat, but not
>> cured it completely, is to make (in your case) a JMastService i.e.
>> not exclusively a Producer or Consumer service. Do that by adding
>> Capability.CONSUMER etc. to the self.capabilities already in your
>> Producer service. This is a bit like the normal VideoService,
>> compared with VideoProducerService and VideoConsumerService. Then use
>> the new JMastService as the producer service while still using your
>> original JMastConsumerService as the consumer service.
>> chris
>> Christoph Willing +61 7 3365 8350
>> QCIF Access Grid Manager
>> University of Queensland
> Ok, I've tried the above and it seems that JMast is getting its own
> address and port now :)
> Thanks Again,
> Ismail
