[AG-TECH] AGService development problem
Ismail Bhana
i.m.bhana at reading.ac.uk
Sun Jan 14 04:58:00 CST 2007
Christoph Willing wrote:
> On 14/01/2007, at 1:01 AM, Ismail Bhana wrote:
>> I've been developing a set of node services called JMast
>> (JMastConsumer and JMastProducer services) which basically provide a
>> form of application sharing using streaming technologies. However,
>> whilst I can get the software to boot from AG 3.0.2 with parameters
>> passed correctly I'm having a problem where I'm being passed the same
>> multicast address/port as the vic tool which causes vic to crash. If
>> I change the Capabilities type (say, from "JMAST" to "jmast1") a
>> different address to vic is assigned in the first instance of
>> execution but the next time I run the software its back to giving me
>> the same address/port as vic and I can't really work out why.
> Ismail,
> I've seen this too in another service we've been developing and would
> be interested in knowing the cause.
> One thing I found which has lessened the problem somewhat, but not
> cured it completely, is to make (in your case) a JMastService i.e. not
> exclusively a Producer or Consumer service. Do that by adding
> Capability.CONSUMER etc. to the self.capabilities already in your
> Producer service. This is a bit like the normal VideoService, compared
> with VideoProducerService and VideoConsumerService. Then use the new
> JMastService as the producer service while still using your original
> JMastConsumerService as the consumer service.
> chris
> Christoph Willing +61 7 3365 8350
> QCIF Access Grid Manager
> University of Queensland
Ok, I've tried the above and it seems that JMast is getting its own
address and port now :)
Thanks Again,
Ismail
