[AG-TECH] Audio/RAT sound not (quite) working
Sam Gundry
sgundry at vpac.org
Thu Jan 11 16:47:44 CST 2007
Hi Morris,
Thanks for the follow up. Unfortunately, I am using a Realtek High
Definition card... Although, subsequent posts suggest the card may work
with RAT 4.23 so I'll give that a go.
I'm currently using 3.2 :/
Cheers,
Sam
Morris Lin wrote:
> Hi Sam,
> In my experience, RAT doesn't support some sound cards. (ex: Reltek
> High Definition Card). You can use another sound card, and try it again.
> Morris
> Sam Gundry wrote:
>> Hi,
>> Audio is not quite working. (Video is working fine, yay!)
>> That is, when I enter a room, RAT is launched fine. Also, if there is
>> someone talking in the venue, my listening slider moves up and down,
>> but no sound is output. I have tested my audio independent of AG and
>> it is working correctly.
>> I think the problem is in Options -> category Audio -> Audio Device.
>> The only option is "No Audio Device".
>> Apparently, from the RAT manual, "No Audio Device" appears only when
>> another process is using the audio device. Although, after closing all
>> programs/process that might be using the audio device, I still haven't
>> had any success.
>> Has anyone experienced anything similar to this?
>> Are there any suggestions?
>> Also, I am using the Audio Reflector accessed from Venue on APAG's
>> Services Lobby. However, when I enter the room, the AudioReflector
>> doesn't appear - as suggested it should here:
>> http://www.accessgrid.org/node/354
>> Is the Audio Reflector room working properly? FYI, I am using AG 3 and
>> logging into the appropriate APAG Lobby (vv3.ap-accessgrid.org).
>> Thanks for any help,
>> Sam
Centre for Computational Prototyping
Victorian Partnership for Advanced Computing
www.vpac.org
