[AG-TECH] Realtek and rat crashing
    Derek Piper
    dcpiper at indiana.edu
    Thu Jan 11 14:54:31 CST 2007
	AGVCR is one app that uses it, but like Tom said it's not much of a
problem yet. If there's no site ID APP packet received, AGVCR will
attempt to match streams in the usual way by matching certain entries of
the RTCP data (like CNAME, NAME etc.)
	Derek
Thomas D. Uram wrote:
> Commenting that out will not cause any problems (yet), as I don't know of
> any applications that use the site id yet.  Eventually it will likely be
> used for
> associating video streams and audio streams with a site, at which time
> commenting that out would cause a problem.
> Tom
> On 1/11/07 2:18 PM, George Estes wrote:
>>   When I try to run the UCL 4.3 RAT from 3.0 I get an address error
>> related to -S.  If we comment out the "pass public id as site id"
>> section in AudioService.py the 4.3 RAT runs fine.  Do bad things
>> happen elsewhere when we comment out that section?
>> George
>> At 11:26 AM 1/11/2007 -0600, Thomas D. Uram wrote:
>>> A couple comments below...
>>> On 1/11/07 8:38 AM, Tom Coffin wrote:
>>>> so - yesterday the soundblaster pcmcia card came and
>>>> I installed it and am testing it out. Initially, everything
>>>> was working great - so I left it up over night. When I
>>>> came in, in the morning, rat had frozen again - as it was
>>>> doing with the realtech card - I disabled and re-enabled and
>>>> the freeze came much faster. I then noted that I was
>>>> still using the rat 4.22... I thought I had copied the latest rat
>>>> into bin and the zip folder.
>>>> So, I tried the latest UCL Rat 4.3 solo - when I run that by itself
>>>> (connecting to one of the NCSA ag3 venues) it works fine
>>>> so I tried to copy over the rats in bin and in the zip folder again
>>>> but the venue still starts up a 4.2 version of rat - is
>>>> there another instance somewhere which I need to copy
>>>> the new rats into?
>>> The rat executables are in your
>>> ~/.AccessGrid3/local_services/AudioService
>>> directory (or c:\documents and
>>> settings\<you>\accessgrid3\local_services\AudioService.
>>> There is a command-line compatibility issue between the AG
>>> rat and the UCL rat, so you can't just drop the UCL rat into
>>> place.  They are planning to fix that by supporting the new option
>>> in a future release.
>>>> Also, I notice that the default configuration always lists
>>>> my video service but it always comes up as disabled - no matter
>>>> how many times i save the config after enabling
>>> That setting is in user preferences (tools->preferences->mynode).
>>> You may have to stretch the window larger, but at the bottom, you'll
>>> see a checkbox for 'enable video'.  Check it and save preferences.
>>>> At 10:47 AM 1/9/2007, you wrote:
>>>>>> At 09:57 AM 1/9/2007, George Estes wrote:
>>>>>>> Thanks Tom,
>>>>>>>  I'm looking at trying a PCI-X card, since I do have an empty
>>>>>>> PCI-X slot.  Either the Sound Blaster X-Fi or the M-Audio card
>>>>>>> look like possibilities.  Although I'm not either will work with
>>>>>>> RAT.
>>>>>>> George
>>>>>>> At 08:45 AM 1/9/2007 -0600, Tom Coffin wrote:
>>>>>>>> hi George - I had the same problms...
>>>>>>>> am going to try out the new soundblaster
>>>>>>>> pcmcia card - if that doesn't work I was
>>>>>>>> going to try the soundblaster external card which connects
>>>>>>>> by usb.
>>>>>>>> I tried updating the rat from UCL and that didn't help
>>>>>>>> not sure why rat and realtek don't work together
>>>>>>>> the audio works fine on other apps
>>>>>>>> On Mon, 8 Jan 2007, George Estes wrote:
>>>>>>>>    > Anyone,
>>>>>>>>    >   I see an old thread about RAT crashing with Realtek
>>>>>>>> drivers.  Does anyone know if that problem has been fixed?  I
>>>>>>>> have a new machine with the latest drivers for an onboard
>>>>>>>> Realtek card and after a period of time RAT becomes
>>>>>>>> unresponsive.  Changing venues causes it to become responsive
>>>>>>>> again.  Of course it's been running for two hours now without
>>>>>>>> hanging.  Has anyone found a solution other than adding another
>>>>>>>> sound card?  Or does anyone know of an affordable PCI-X sound card?
>>>>>>>>    > Thanks,
>>>>>>>>    > George
>>>>>> ___________________________________________________________
>>>>>> Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
>>>>>>   NCSA-ACCESS                         cel: 703-477-5948
>>>>>>   901 North Stuart Street, #800       tel: 703-248-0105
>>>>>>   Arlington, Virginia 22203           fax: 703-248-0100
>>>>>> _________________________ http://www.ncsa.uiuc.edu/~tcoffin
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
