[AG-TECH] Audio/RAT sound not (quite) working
    Morris Lin
    n00lcc00 at nchc.org.tw
    Thu Jan 11 01:35:14 CST 2007
Hi Sam,
    In my experience, RAT doesn't support some sound cards. (ex: Reltek
High Definition Card). You can use another sound card, and try it again.
Morris
Sam Gundry wrote:
> Hi,
> Audio is not quite working. (Video is working fine, yay!)
> That is, when I enter a room, RAT is launched fine. Also, if there is
> someone talking in the venue, my listening slider moves up and down,
> but no sound is output. I have tested my audio independent of AG and
> it is working correctly.
> I think the problem is in Options -> category Audio -> Audio Device.
> The only option is "No Audio Device".
> Apparently, from the RAT manual, "No Audio Device" appears only when
> another process is using the audio device. Although, after closing all
> programs/process that might be using the audio device, I still haven't
> had any success.
> Has anyone experienced anything similar to this?
> Are there any suggestions?
> Also, I am using the Audio Reflector accessed from Venue on APAG's
> Services Lobby. However, when I enter the room, the AudioReflector
> doesn't appear - as suggested it should here:
> http://www.accessgrid.org/node/354
> Is the Audio Reflector room working properly? FYI, I am using AG 3 and
> logging into the appropriate APAG Lobby (vv3.ap-accessgrid.org).
> Thanks for any help,
> Sam
