[AG-TECH] Osprey 400 Video capture
Matthew Rendell
matthew.rendell at flinders.edu.au
Thu Jan 4 15:41:09 CST 2007
We found this problem was caused by not having the camera image size set
in your video capture settings (usually can be set through VIDCAP in
WinXP or your camera software, can be found in the "system 32" folder I
believe) not being set to the correct CIF size.
NTSC CIF (which is 30 frames/sec) has a field resolution of 352 x 240
PAL CIF , (which is 25 frames/sec) has a higher 352 x 288 resolution.
This is an issue we have here in Australia as usually most cams default
to NTSC
It just seems a bit backwards that if you are in NTSC that you would
have a grey border around your image, but try one of these video sizes..
Hope that helps ya out
Cheers
Matt Rendell
Usually we have found that this is
Amarnath Reddy wrote:
> Hello,
> We are having a small problem with the Video Capture card. We recently upgraded our AG server(runs on Win XP). With the new capture card, we get a gray border for the video output. Did anyone face this problem before? Please let me know the solution to fix this problem.
> Thank you
> Amarnath
> Systems Support
> Center for Computational Sciences
> Univ of Kentucky
*Matt Rendell*
ICT Officer
Communication Services
Flinders University
GPO Box 2100
Adelaide SA 5001
Telephone: 8201 5728
Fax: 8201 3003
matthew.rendell at flinders.edu.au <mailto:matthew.rendell at flinders.edu.au>
/This email message is intended only for the addressee(s) and/
/contains information which may be confidential and/ or copyright./
/If you are not the intended recipient of this email please do not/
/read, save, forward, disclose or copy the contents of it and delete it/
/ and any copies or links to this email completely and immediately /
/from your system.///
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070105/e8c548ba/attachment.htm>
