[AG-TECH] RAT on 64bit RedHat
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Feb 13 22:53:44 CST 2007
Hi Ashley,
> $ file rat-4.2.22
> rat-4.2.22: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), for
> GNU/Linux 2.2.5, dynamically linked (uses shared libs), stripped
> Will I need a 64bit version to fix this issue? And if so is there a good
> place to get one (maybe FC5 or 6 rpms?)
The x86-64 FC5 AG3 yum repo comes with a 32bit rat. I just ran it now on
x86-64 FC5 and don't get the same symptoms. All of the 32bit rat RPMs were
built on 32bit Fedora and copied across.
The SRPMs for rat should be the same for FC3, 4 and 5. The FC6 version
includes ALSA support. Find them under:
http://www.vislab.uq.edu.au/accessgrid3/fedora/
If you rebuild the AccessGrid-rat SRPM on x86-64 RHEL, it will apply a 64bit
patch and build a x86_64 RPM. I don't have a proper install of x86-64 FC3 as
it was too old to run on the hardware I have, I just chroot to a x86-64 FC3
partition that was copied across from elsewhere. Perhaps rebuilding rat on
RHEL might fix it.
I think I may have included a 64bit rat with FC6, but that was
unintentional.
Cheers,
Doug
> Douglas Kosovic wrote:
>> Hi Ashley,
>>> We are running AG 2 & 3 on a x86_64 RedHat EL4 machine (FC3 RPMS), and
>>> our RAT displays SSIDs where it should be displaying site names.
>>> Has anyone come across this before, and know of a solution.
>> Are you running a 32bit or 64bit rat? You can use 'file
>> /usr/bin/rat-4.2.22' to check. At one stage I did put up a 64bit rat in
>> the AG3 x86_64 FC3 yum repository, but it was broken, so replaced it with
>> the 32bit FC3 version.
>> Doug
> Ashley Wright
> HPC and Research Support Group
> Queensland University of Technology (QUT)
> Ph: (07) 3138 9236
> Mobile: (04) 0531 3124 QUT: #66866
> Email: a2.wright at qut.edu.au
