[AG-TECH] RAT on 64bit RedHat
Ashley Wright
a2.wright at qut.edu.au
Tue Feb 13 21:12:46 CST 2007
Hi Doug,
$ file rat-4.2.22
rat-4.2.22: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV),
for GNU/Linux 2.2.5, dynamically linked (uses shared libs), stripped
Will I need a 64bit version to fix this issue? And if so is there a good
place to get one (maybe FC5 or 6 rpms?)
Ashley
Douglas Kosovic wrote:
> Hi Ashley,
>> We are running AG 2 & 3 on a x86_64 RedHat EL4 machine (FC3 RPMS),
>> and our RAT displays SSIDs where it should be displaying site names.
>> Has anyone come across this before, and know of a solution.
> Are you running a 32bit or 64bit rat? You can use 'file
> /usr/bin/rat-4.2.22' to check. At one stage I did put up a 64bit rat
> in the AG3 x86_64 FC3 yum repository, but it was broken, so replaced
> it with the 32bit FC3 version.
> Doug
Ashley Wright
HPC and Research Support Group
Queensland University of Technology (QUT)
Ph: (07) 3138 9236
Mobile: (04) 0531 3124
QUT: #66866
Email: a2.wright at qut.edu.au
