[AG-TECH] Video Producer Service fails to start
Mike Weaver
weaver at ascr.doe.gov
Fri Feb 9 06:15:39 CST 2007
Chris,
It's 'fixed' in the sense that I'm successfully using the VideoService
now instead of the VideoProducerService, but it's a hard error in the
VPS, every time.
The problem occurs when configuring the node, specifically when I try to
enable the video. I haven't even gotten to a venue yet.
Mike
-----Original Message-----
From: Christoph Willing [mailto:willing at vislab.uq.edu.au]
Sent: Friday, February 09, 2007 01:39
To: weaver at ascr.doe.gov
Cc: ag-tech at mcs.anl.gov; Douglas Kosovic
Subject: Re: [AG-TECH] Video Producer Service fails to start
On 02/02/2007, at 9:56 PM, Mike Weaver wrote:
> Apologies if this shows up twice, but it's been almost 18 hours,
> nobody's
> queues run that long! Also, Chris & Doug, I hope you don't mind me
> copying
> you directly.
Mike,
There's no clear answer yet, but we've seen the problem occasionally
on multiple systems, ruling out a distribution related solution.
Can the problem be consistently reproduced? One thing I've noticed is
that sometimes the problem has just gone away if I come back to it
another day.
Another thing to try is to re-enter the venue. This updates the
stream information in the VenueClient from the venue i.e. the service
in question may then be using "better" stream information.
chris
> From: Mike Weaver [mailto:weaver at mics.doe.gov]
> Sent: Thursday, February 01, 2007 13:29
> To: 'AG-TECH list'
> Subject: RE: [AG-TECH] Video Producer Service fails to start
> Hi all,
> I finally had time to start looking at this again. This problem is in
> reference to AG 3.0.2 on Fedora Core 6. The actual error (detailed
> below)
> is
> VideoProducerService.py", line 279, in Start
> if self.streamDescription.encryptionFlag != 0:
> AttributeError: 'int' object has no attribute 'encryptionFlag'
> Python seems to be misinterpreting the data type of the
> streamDescription
> object. Hacks to comment out this check, or surround it with a
> 'hasattr'
> check only cause failures further in the code.
> The really annoying thing about this, is that the AudioService.py
> module
> (different machine) has almost identical code and runs fine. The
> audio &
> video machines use the same motherboard, BIOS, chipsets, etc...
> Both are
> fresh installs of Fedora Core 6, fully patched with the latest AG3
> & 2.4
> compatibility RPMs from the UQ repository. All python packages are
> identical, same packages, same versions.
> I'm no python guru, but I have a (outdated) software development
> background
> and I just can't understand how this can be. Same platform, same
> OS, same
> libraries, same versions, same code - different results.
> Anyone out there have any ideas? I'm willing to try other Linux
> distros,
> but we run RHEL on our production servers so I'd like to stay with
> Fedora
> for consistency's sake.
> I've attached both the AudioService.log & VideoProducerService.log
> files for
> review & comparison.
> Thanks,
> Mike
> From: Rhys Hawkins [mailto:rhys.hawkins at anu.edu.au]
> Sent: Tuesday, November 14, 2006 17:32
> To: Christoph Willing
> Cc: weaver at er.doe.gov; AG-TECH list
> Hi Chris, Mike,
> This looks like the same thing that bit me when testing UQs h263
> stuff.
> If the streamDescription is an int, then the VideoProducer service
> doesn't stand much of a chance being able to start. It appears to be
> a bug that rears its ugly head when you least expect it, ie I've just
> tested this again and now I don't see the same problem ...
> It would be interesting to know if this is restricted to Fedora or if
> it occurs on other ports.
> Cheers,
> Rhys
> On Wed, 15 Nov 2006 08:11:12 +1000
> Christoph Willing <willing at vislab.uq.edu.au> wrote:
>> On 15/11/2006, at 6:16 AM, Mike Weaver wrote:
>>> The relevant part of the VideoProducerService.log seems to be:
>>> 11/14/06 14:45:05 -1225061488 Toolkit VideoProducerService.py:
>>> 309 ERROR
>>> Exception in VideoProducerService.Start
>>> Traceback (most recent call last):
>>> File
>>> "/home/micsag/.AccessGrid3/local_services/VideoProducerService/
>>> VideoProducer
>> Mike,
>> A short term fix is to edit the file .AccessGrid3/local_services/
>> VideoProducerService/VideoProducerService.py by changing the line:
>> to
>> if hasattr(self.streamDescription, 'encryptionFlag') and
>> chris
>> Christoph Willing +61 7 3365 8350
>> QCIF Access Grid Manager
>> University of Queensland
>> <AudioService.log>
>> <VideoProducerService.log>
